Go Back   Automotive Forums Car Chat > Plymouth > Fury/Gran Fury
Old 07-18-2011, 05:06 PM
RARoMiNous RARoMiNous is offline
1985 Plymouth Gran Fury brake lights
So the other night I got pulled over for the first time on account of my brake lights not working. I was pretty perturbed seeing as I had just replaced them less than a month ago and so I took a look at them. What I discovered is that my brake lights work when my headlights are off, but not when they're on. I have no idea what the problem is, so any help at all would be appreciated.
Old 07-19-2011, 11:28 AM
jdl jdl is offline
Re: 1985 Plymouth Gran Fury brake lights
In the diagram, Check the ground circuit wiring. If problem with ground, the tail lamp maybe trying to ground through the brake/turn voltage circuit. If you can't read the diagram, Gray wire is ground. Black wire is voltage tail lamps. Brown wire is voltage for stop and turn.
1987 Plymouth Gran Fury - Police Package AHB Code - 83K Original Miles - $2100 heavydude Fury/Gran Fury 2 11-27-2014 09:20 PM
99 Alero No Rear Lower Brake Lights rjs0421 Alero 5 03-09-2011 07:31 AM
2004 Sentra 1.8S-No brake lights?!? brynfrt05 Sentra | 200SX (USDM FWD) 11 06-08-2010 09:30 AM
Locked front brakes, brake light out, headlights gone kruqnut Problem Diagnosis 19 02-26-2009 08:49 AM
1987 Plymouth Gran Fury ahs2003 Fury/Gran Fury 4 03-28-2004 11:26 AM
