Go Back   Automotive Forums Car Chat > Ford > Crown Victoria
Old 07-18-2011, 12:37 AM
Mark72 Mark72 is offline
98`Crown vic p71 hesitation problem
Acceleration sucks unless i stand on it!
What kind of cleaner do you use on the MAF?
No codes,Cats good,plugs good,o2 sensors good.
I dont believe its a fuel problem either.
I work on cars all the time,but i dont know it all.
I also dont know much about the DPFE sensor but i guess could be part of the problem.
Thanks for the forum,it has helped me alot.
Any ideas? Thanks
Old 07-22-2011, 06:31 PM
p71Interceptor p71Interceptor is offline
Re: 98`Crown vic p71 hesitation problem
could be a coil going out mine 2000 crown vic p71 had hesitation too but no light or codes but after a while of driving it the check engine light started to flash got the codes and 2 of my coils were messed up. i also had bad stutter and hesitation and engine will turn off while at high speed it was the crank sensor that can maybe be your cars problem too. hope this helps
Old 08-16-2011, 06:19 PM
Thank`s I will check those out.
98 crown vic rear end problem hdman87 Crown Victoria 3 10-06-2009 09:27 PM
04 PI Crown Vic Zeepian Crown Victoria 0 03-29-2009 01:54 PM
98 Crown Vic LX Headlight Problem noble5.0 Crown Victoria 1 02-26-2007 03:07 AM
96 Crown Vic Starting/hesitation Problem Aje Crown Victoria 4 01-29-2005 07:23 PM
'00 Crown Vic P71 w/ Electrical Problems? FirefighterGuy47 Crown Victoria 1 01-29-2005 04:48 PM
