Old 07-17-2011, 09:37 PM
gregger44 gregger44 is offline
Stuck hub bearing
Can anyone give me some ideas on how to free up a hub bearing that is stuck? I have a 99 Buick LeSabre.
Thanks in advance
Old 07-17-2011, 10:24 PM
HotZ28's Avatar
HotZ28 HotZ28 is offline
AF Moderator Elite
Re: Stuck hub bearing
http://www.youtube.com/watch?v=G4pygRExlus
http://www.youtube.com/watch?v=eB9mr...eature=related
Old 07-19-2011, 02:42 PM
jeffcoslacker's Avatar
jeffcoslacker jeffcoslacker is offline
Lactose the Intolerant
Don't understand the question.
You're trying to remove it, and it won't come off? You trying to drive it, and the wheel doesn't turn, what?
If you're trying to remove it and you've taken the four mounting bolts off and it seems stuck at the top, there's two little posts that come in from behind that locate the mount plate for the ABS sensor, they get all cheezed up on the outside and won't pull through, so the bearing doesn't wanna come off....juts spray 'em with penetrating lube and tap them gently while pulling the bearing towards you...
You made three mistakes. First, you took the job. Second, you came light. A four man crew for me? F**king insulting. But the worst mistake you made...
...empty gun rack.
Old 07-20-2011, 03:30 PM
I should clarify myself. The bearing is stuck on the drive shaft. I got it out of the steering knuckle. Would a big "F"ing hammer work?
Old 07-20-2011, 06:43 PM
imidazol97 imidazol97 is offline
AF -Advisor
In their loaner tools,
Autozone has a axle flange puller or some name like that; #27037. Three lug bolts on the bearing go through the holes and put the lug nuts on top and then a prong in the middle that you screw in and it pushes against the axle shaft while the others are pulling. That unsticks it.
http://contentinfo.autozone.com/znet...27037/image/2/
http://www.autozone.com/autozone/acc...uller/_/N-264n
Old 07-20-2011, 09:59 PM
HotZ28's Avatar
AF Moderator Elite
Yes, if you use PBblaster on the splines, prior to the hammer job. Be sure to put the nut back on the shaft before using the hammer. Always use a new nut when replacing hub bearings.
Old 07-22-2011, 01:18 PM
I spray the splines, put a block of wood against the stub and hit it with a hammer. Once it starts to push in, keep tapping gently on the stub while pulling the bearing forward...being careful not to stretch the inner joint on the shaft too much, or the tripot will fall apart...that's always fun to try to get those balls to go back in place.
The main thing is don't bang up the threads on the end of the shaft stub, or you've got problems. A plastic hammer is handy, but most people don't have one...
...empty gun rack.
1999 Cavalier Wheel bearing problem RobbWis Cavalier Problem Diagnosis 0 04-30-2011 01:15 PM
'00 SL2 bearing/hub replacement? nathyrin SC/SL/SW 1 02-28-2011 09:30 PM
front bearing - new or junkyard replacement? gijmcd Sonata 5 02-15-2010 07:15 PM
99 T&C Front Bearing? SlimJimRD Caravan | Voyager 7 06-03-2009 11:37 AM
2001 4x4 Hub Bearing Assembly Stuck HELP plopper73 Problem Diagnosis 2 07-15-2007 07:03 AM
