Old 07-17-2011, 07:03 PM
GeoRandy GeoRandy is offline
Radiator Drain Petcock, where is it?
I have a 2004 GMC Safari and the coolant is a nasty rusty soup. Thought I'd simply drain the system, flush it, and replace with new fluid just like I have done on my '85 and '92 Astro/Safari vans.
But no! The little recessed circle on the passenger side at the bottom of the radiator is sealed. There is no petcock. There is the usual little drain pipe below it at the bottom of the radiator BUT THERE IS NO PETCOCK TO TURN. What is the deal? How am I to drain the radiator?
The lower hose on the radiator is an option, I know, but it is so high I don't think I will adequately remove all the rust and junk at the bottom of the radiator. I can't just turn the van upside down and shake it.
Anybody know how to drain the radiator on a 2004 GMC Safari Van?
Old 07-17-2011, 07:11 PM
Treenail Treenail is offline
Re: Radiator Drain Petcock, where is it?
The petcock is allegedly located on the passenger side below the large radiator hose. I think I touched it with my finger tips but I can NOT figure out how to drain it with the radiator bolted in place.
Good luck! I just pulled off the hose and made a mess
Old 07-17-2011, 11:06 PM
There is an indented circle where a petcock goes, right above the little drain tube that points down, on the passenger side. Just like all my old Safaris' except there seems to be a pressed in plug in it where a petcock should go. Only daylight above the little drain tube pointing down. No wings or 1/4" drive in the plug either. Is it possible that in the 2004's they did not put a drain at all? Owner manual says service after 150,000 miles, that's crazy but maybe why I've not done it before now.
Old 09-15-2011, 08:10 PM
Wmurky Wmurky is offline
i have a 2000 astro it never had one and neither did the replacement, get prestone back flush kit, use prestone cleaner and ditch the dex cool it beaks down when it gets old and turns into greasy globs and the engine starts to rust.
Radiator drain petcock ZUZURODEO Rodeo | Passport | MU 2 11-26-2009 12:02 PM
Removal of 97 Radiator Drain Petcock? tigerbalm2424 Jimmy 3 05-22-2007 03:28 PM
1999 Grand Am SE 2.4 Radiator drain plug where is it? x_smoke_1 Grand AM 1 11-18-2005 02:17 PM
Radiator Drain Petcock??? Troop2fish Trooper | SLX | Bighorn | Wizard 1 06-06-2005 05:24 PM
1999 Yukon radiator drain petcock location hcwarnerjr Yukon 2 05-17-2005 12:49 PM
