Old 07-17-2011, 05:43 PM
evn711 evn711 is offline
95 civic ex brake light problem
The tail lights work and the headlights work, but no brake lights. All fuses have been checked and switch has already been replaced. Anybody experienced this before? Any ideas besides tracing power from the bulb connector back? Any help is greatly appreciated, thanks.
Old 07-17-2011, 05:53 PM
Moppie's Avatar
Moppie Moppie is offline
Master Connector
Re: 95 civic ex brake light problem
G'day. welcome to AF
Assume all the bulbs are good?
It could be the switch under the pedal.
Old 07-17-2011, 06:41 PM
Yea, i originally thought so too. But the switch was already replaced....Without a good wiring diagram, all I can think to do is check for the correct voltage at the bulb connectors and depending on the results, and if they vary per connector go from there...and thanks by the way. I've never joined an online auto forum so this is a little new to me.
Old 07-18-2011, 01:41 AM
Moppie's Avatar
Master Connector
No worries.
I've around forums since last century, they are very useful and cool places on the web
The wiring is pretty simple.
I'm pretty sure they share a ground with the rest of the lights in the cluster.
It could be a bad relay?
Old 03-23-2012, 07:35 PM
Galuple Galuple is offline
Check the bulbs because they're dual filament bulbs. Mine looked fine and when I replaced them it worked again.
95 civic EX brake light problem neosky5k '92-'95 Civic | EL | Civic Hybrid | Civic GX NGV 2 02-07-2011 03:30 PM
emergency brake light comes on freakyfire05 ZX2 8 02-11-2010 11:19 AM
Brake lights stay on -- not the brake light switch davewah3 Problem Diagnosis 2 10-30-2008 12:36 PM
87' Honda Civic brake lights stuck on TagCdog '71-'87 Civic | CRX 3 08-04-2006 01:33 PM
'95 civic brake lights jandcpyle '92-'95 Civic | EL | Civic Hybrid | Civic GX NGV 0 08-18-2003 06:58 PM
