Go Back   Automotive Forums Car Chat > Oldsmobile > Eighty Eight
Eighty Eight Includes the '97-'98 Regency and '96-'99 LSS Models
Old 07-17-2011, 11:13 AM
robzombie92881 robzombie92881 is offline
Power window switches blown
I have a 1987 Delta 88, and when trying to use the power windows (from the driver's panel), there was a "pop" within the switch, and now the down button doesn't make the clicking sound when it is pushed, but the up button still goes click. This has happened to all four switches on the driver's panel. Any help would be much appreciated. Thanks
Old 08-03-2011, 09:45 PM
gmtech1's Avatar
gmtech1 gmtech1 is offline
Re: Power window switches blown
Do the windows still work?
Old 08-04-2011, 03:53 AM
No, none of the windows work at all. Had to take the door panel off, and take out a few bolts to get the window to go down. Has been extremely hot, so I had to figure something out. Just starting Auto Tech. classes in 2 1/2 weeks, so as of right now, I barely know anything about this issue.
Old 08-04-2011, 03:55 AM
AND, the windows do not work when the switches are used on the individual doors either.
Old 08-04-2011, 07:39 AM
gmtech1's Avatar
You need to check circut breaker #23 in the fuse block (30 amp) if its ok and has power to it, check for power at pink wire of master switch (key on), check the black wire at the switch (ground ckt) and make sure its ok. If power and ground circuts are ok, replace the switch. The master switch provides the ground for all the windows.
Power Window Switch or window Motor? Help Virlan Montana/Montana SV6 2 11-26-2008 12:57 PM
Driver's side power window motor blown! Wayne Gail Thunderbird 4 01-15-2007 12:17 AM
power window switches turok Accord/TSX/Accord Hybrid 0 02-23-2002 12:48 PM
