Old 07-16-2011, 10:01 PM
goodysguitars goodysguitars is offline
stiff brakes
Hi all, need advice. Brakes on 98 z71 are stiff, stop and go traffic they become stiffer with every let off/apply. The engine revs up a little sometimes when I apply brakes, i have no idiot lights on dash, is this the booster? Other than this, the brakes are great, just feel like my 72 chevy with no power assist (great truck!) Anyway, thanks!!!
Old 07-16-2011, 11:20 PM
procaddytech procaddytech is offline
Re: stiff brakes
Sounds like a vacuum booster. Can you hear a hiss noise from in the truck when you are sitting still with the truck runnig and slowly apply the brake? That would be another sign of a bad booster. With the trck off, pump the brake pedal a few times to get the booser free from residual vacuum and hold it. While pressing on the brake, start the engine, If the booster is in good condition, the pedal will travel downward considerably.
Old 07-17-2011, 09:13 AM
j cAT j cAT is offline
Re: stiff brakes
hard brake pedal is usually the brake booster or any vacuum lines gromets fittings connecting the vacuum to the booster. since the idle increases when pedal is depressed I would say the booster is with a leaking diaphram..you may notice after this repair , the engine runs smoother..
Old 07-17-2011, 08:50 PM
Re: stiff brakes
Thank you both very much for your time, I appreciate the tips, due to the sun melting Illinois, it will be a day or two before I let you know if thats what it is!! Thank God for the old goldwing!
97 Astro Stiff Brakes redbird7 M Bodies 3 06-23-2009 07:30 PM
Please Help... 1999 Contour SE Stiff brake pedal but idle is fine seiguy Contour 3 02-15-2008 07:48 AM
Stiff brake pedal which ratchets to floor bigkylewhite Suburban 3 01-27-2008 10:25 AM
Stiff brake pedal NateS Eclipse Problem Diagnosis 0 10-21-2005 05:33 PM
has ne 1 had stiff brakes on a 91 passat nycdub2 '88 - '92 0 10-08-2004 10:02 AM
