Go Back   Automotive Forums Car Chat > Mazda > 3
Old 07-16-2011, 06:49 PM
2000oldsilh 2000oldsilh is offline
pcv valve
Im trying to locate pcv valve on my 04 mazda3 2.3L and I cant find it. Did any of you replaced it yet. Thanks
Old 07-16-2011, 07:21 PM
Moppie's Avatar
Moppie Moppie is offline
Master Connector
Re: pcv valve
G'day,
Have you looked the vent cable from the side, or top of the valve cover?
It will be quite thick tubing, and run through the valve and back into the intake.
Old 07-17-2011, 10:29 AM
danielsatur danielsatur is offline
Re: pcv valve
See http://www.alldata.com ,you might need to remove the Intake!
Old 07-17-2011, 03:24 PM
Moppie's Avatar
Master Connector
Re: pcv valve
I've tried Alldata, are there any catches to registering, which it seems you need to do to access the information?
Old 07-17-2011, 05:52 PM
Re: pcv valve
@ checkout.Alldatadiy.com + $16.95
Do a Alldatadiy.com (DIY) Login to access your car.
Maintenance, DTC's,TSB's, Specs, Diag repair, and Locations of parts.
Service procedures, Troubleshooting procedures, removal, disassemble, and repair.
Old 09-09-2011, 08:29 PM
OttawaTech OttawaTech is offline
Re: pcv valve
you have to pull the intake. it's right in the middle.
Differences between PCV Valves CCMphysician General Discussion 5 01-13-2010 01:14 PM
PCV Valve Replacement CCMphysician General Discussion 0 01-13-2010 12:36 PM
PCV Valve carmic General Discussion 3 01-26-2004 07:41 PM
PCV Valve??? ChuckH Pathfinder | Terrano | QX4 | Xterra | Patrol | Safari | X-Trail 6 11-20-2001 02:25 AM
