Old 07-16-2011, 02:25 PM
y2kpa2's Avatar
y2kpa2 y2kpa2 is offline
Village Idiot
Abs codes
2000 buick park ave vin k abs codes i am getting c1214 c1248 i know very little about abs, any suggestions on what to do about this one?
thanks y2kpa.
My Fleet 2000 F-150, 2012 Chevy Impala LTZ
Old 07-16-2011, 05:08 PM
HotZ28's Avatar
HotZ28 HotZ28 is offline
AF Moderator Elite
Re: Abs codes
DTC C1214 System Relay Contact or Coil Circuit Open. The C1214 indicates that the relay inside the EBCM that powers up the BPMV pump and the solenoids in the BPMV has failed. Without this relay the EBCM cannot power up the BPMV components when needed. That is why the C1214 causes the loss of all the systems that require control of brake line pressure .... you have lost ABS, Traction Control, and Active Handling.
DTC C1248 EBCM Turned the Red Brake Warning Indicator On. This is more than likely the result of a failed solenoid/coil, or bad ground. For more info & repair service, Click Here
The Following User Says Thank You to HotZ28 For This Useful Post:
y2kpa2 (07-21-2011)
Old 07-21-2011, 10:28 AM
y2kpa2's Avatar
Village Idiot
Re: Abs codes
thanks hot z28, just another reason to consider buying a new camaro or mustang i love the park ave but all the "little" electronic stupid problems are starting to act up along with suspension problems. cause abs problems can be very expensive
y2kpa2
2000 Alero 3.4 ABS light on, code c1265 skeeter123 Alero 8 01-26-2010 08:51 AM
What type of code scanner do I need for ABS codes brj1 General Discussion 2 04-22-2007 01:02 PM
Code Reader for ABS Codes inmavt2 Grand Marquis 1 02-01-2006 12:53 PM
97 suburban abs code danjm C/K 0 02-02-2004 04:33 PM
ABS Code coyote03 Taurus | Taurus Wagon 0 11-21-2003 01:05 PM
