Old 07-16-2011, 01:06 AM
thinmints thinmints is offline
96 Xj, Strange AC problem
My 96 xj with 260000 miles 4.0 has a very odd problem when i turn on the AC it will blow cold air out the vents BUT when i am going down the hwy it will suddenly stop blowing out the vents and the air will come from the windshield vent as if i had put it in defrost mode. but when i let off the gas pedal it will come back out the side vents it seems to be getting worse as time goes by. any ideas ? it doesn't matter if its on max or regular AC it will still do it and it seems only to happen when I'm on the hwy and not when I'm driving around town
Old 07-16-2011, 09:45 AM
Saudade's Avatar
Saudade Saudade is offline
Re: 96 Xj, Strange AC problem
You have a vacuum leak. It's either a small hole somewhere in the vacuum line or a bad check valve.
At high throttle settings, acceleration, climbing hills, etc, the engine sees low vacuum. Normally, the reservoir holds enough vacuum to get through these relatively short periods. As soon as you back off the throttle, you increase engine vacuum. If you have a small leak or bad CV, the vacuum bleeds off faster and the vents default to defrost.
You don't see it around town because the low vacuum periods are typically much shorter than on the freeway. Starting from a red light on a side street takes less time than accelerating to freeway speeds or climbing up a long hill.
Dad's taxi:
'88 XJ - 190K and going strong.
K&N, Ford Injectors, No other mods
Old 07-16-2011, 01:07 PM
[quote=Saudade;6912664]You have a vacuum leak. It's either a small hole somewhere in the vacuum line or a bad check valve.
whats the best way to check for a leak? also can you tell me where to look for the check valve?
Old 07-17-2011, 05:15 PM
denisond3 denisond3 is offline
I check for vacuum leaks by going over the vacuum lines -tubing and hoses - and closely examining each joint. With the mileage on your jeep, you can expect some really deteriorated rubber hoses, cracked plastic tubing, or joints that have begun to pull apart.
Old 07-25-2011, 10:05 PM
fredjacksonsan's Avatar
fredjacksonsan fredjacksonsan is offline
Caution: Monkeys bite!
Send a message via AIM to fredjacksonsan
I'm not sure about Cherokees, but in Wranglers there is a junction point that goes bad; I'd check the schematic to see if there's a similar junction in the Cherokee.
Ours: 2020 Jeep Wrangler 2.0, 53k
2013 Toyota FJ Cruiser, 84k
Kids: 2005 Honda CRV, 228k
XJ Electrical Problems JeepInBlack Cherokee 3 12-29-2006 07:37 AM
1990 Xj seat problem...... Projectxj Cherokee 4 06-28-2006 07:35 PM
89 xj idle problem jeepguyxj Cherokee 3 01-08-2004 12:43 PM
91' XJ Electrical Problem DDX Cherokee 4 08-08-2003 02:53 PM
