Go Back   Automotive Forums Car Chat > Oldsmobile > Bravada
Old 07-15-2011, 07:58 AM
racejunky racejunky is offline
Send a message via AIM to racejunky
brain buster
I recently bought a '92 bravada brought it home and discovered that it would run beautifully for about 10 miles and then I would have to head back to the house. Needless to say it has reached the point that it will not run at all. If I do manage to get it to start I have to pump the accelerator frantically and constantly to keep it running and it runs like crap even then. I have worked with it for awhile now and have found that if I swap out the ECM with one out of an unknown year and model Blazer (at least I think it was a Blazer) that I bought from a junkyard it will crank up and run fine. The only problem here is It burns a lot of gas and I can't use the a/c. When I turn the a/c on while driving it around it drives the tranny crazy and causes it to constantly shift up and down. I would like very much to salvage the truck but I am at my wits end here and am about a hairs bredth from parting it out. ANY ideas here would be greatly appreciated.
Old 07-15-2011, 06:53 PM
maxwedge maxwedge is offline
A990 racer
Re: brain buster
Hmm, ever think about getting the proper pcm?, if the wrong one seems to help.
Old 07-15-2011, 08:34 PM
ericn1300's Avatar
ericn1300 ericn1300 is offline
AF Premium User
Re: brain buster
The ECM may be the same on both vehicles but the chip inside is unique to the vehicle. If you still have the old ECM you can try swapping the EPROM chips inside the ECM and see if that fixes it.
Old 07-15-2011, 09:57 PM
Chris Stewart's Avatar
Chris Stewart Chris Stewart is offline
AF - Advisor
Re: brain buster
I agree with Eric, certainly worth a try.
Hey Maxwedge, Tony DePillo has a site,
http://honkinhemi.com/
Old 07-17-2011, 08:25 PM
Re: brain buster
I neglected to say that I have replaced the old ECM and PROM with a reman ECM and a brand new factory PROM, but it still will not run with the original equipment. The junkyard ECM has a different PROM in it so they will not swap.
Old 07-18-2011, 07:28 PM
AF - Advisor
Re: brain buster
Is the Check Engine light on?
Does it come on momentarily then go off after first turning the keyswitch on?
Do you know how to check for stored DTC's?
I'm kinda leaning towards the TPS.
Old 07-19-2011, 01:27 PM
Re: brain buster
the engine light is on until I try to start the truck, it goes off while the truck is trying to run and then comes back on as soon as the truck shuts down. the trouble code just flashes a code 12 repeatedly with no other codes in the mix. If by TPS you mean throttle position sensor I pray that you are correct. I haven't tried that yet and that's why I am looking to y'all for a direction to go in. So far that's the only suggestion that has been made. If you think that may be the problem I'll give it a shot. Thanks for the help.
Old 07-19-2011, 09:26 PM
AF - Advisor
Re: brain buster
This is odd. Mine and Eric's '92's are pretty good about setting a code whenever there's a sensor issue.
Since it's acting up after the engine is warmed up, it's in closed loop and all the sensors should be active. Those not within parameters should have the ECM setting off the Check Engine light and storing DTC's.
Sorry racejunky but it may end up requiring a look with a Pro shop type OBD I scan tool.
Old 07-19-2011, 10:02 PM
Re: brain buster
Just to make sure there is no misunderstanding about the problem The truck does not have to warm up before the problem occures. It is there from jump street. I don't know if that makes a difference or not but If so maybe it would help to know that. I have an OBD II but I don't think it will fit the data link plug. do you know of an adapter or will I need to accquire an OBD I in order to run a check on it?
Old 07-20-2011, 07:22 AM
AF - Advisor
Re: brain buster
So we're still at starting, running, and driving fine until the AC is turned on, then the trans has a shifting fit?
If so, what does the voltmeter show with the AC on?
Some of the Actron's just need a cable.
Old 07-20-2011, 11:20 AM
Re: brain buster
the only way it will start, run and drive is when I have the ECM from the junkyard installed. with the original ECM it will start but only momentarily and it runs rough for that short moment. But yes when I have the ECM from the junkyard installed the a/c drives the tranny nuts when I turn the a/c on and am driving around. It seems to work fine if I'm sitting still and the truck is in park. I can drive the thing all over if I don't use the a/c it just gets horrible fuel mileage.
Old 07-20-2011, 11:21 PM
AF - Advisor
Re: brain buster
Electrical noise from a questionable alternator makes the transmissions act up on Dodge Diesels.
What does your voltage look like w/AC on?
Old 07-21-2011, 05:38 AM
Re: brain buster
I will check it and see, if I remember correctly I think the guy I bought it from said He had just replaced the alternator. With all these new electronic gizmo's I suppose it could be anything. That's why I deffer to someone with more knowledge of these things.
I have a Brain Buster Question (Car Related) MIKES3 Grand Prix 1 07-05-2006 04:51 PM
I've got a brain buster of a problem w/my zx3 stringcheese Focus | C Max 31 11-07-2005 07:58 PM
brain buster s-10 prob jl1234567890 S-10 11 04-02-2005 06:14 AM
Best "Fuzz Buster?" Volume_Civics Car Audio 2 03-28-2004 04:58 PM
IL any car meet in Addison Dave & Busters 20th maxstyle Nissan Cefiro | Nissan Maxima | Infiniti I30 | Infiniti I35 1 09-29-2001 05:47 PM
