Old 07-11-2011, 08:22 PM
4x4junkie 4x4junkie is offline
thumping sound in front driver side
I have started hearing a thumping sound from the driver side front wheel well. It sounds identical to a tire with a broken belt in it. While driving down the road at speeds above 15 MPH it gets louder and faster with the vehicle speed increasing. The only time the sound stops is while turning at roadway speeds, it did the exact same thing a few months ago and when I rotated the tires it stopped. This time i tried rotating tires but it did not help so I then replaced my tires as they had high milage and the tread was about 75-80% worn and due for replacement anyways.
Today I had the wheels off and inspected the brakes, rotors, drive axles (there was no up down or side to side movement) and have found nothing to implicate what part might be failing. It was 100 degrees here today and 110 heat index, so i stopped before removing the ABS sensor to check the color of the grease in the wheel bearing hub assembly but there appeaed to be no movement in the bearings and the sound dioes not start until i reach speeds of 15 MPH or above.
Open to more suggestions before replacing parts.... i intend to check the wheel bearing grease color tomorrow.
4x4Junkie
2012 silverado 1500 ext. cab LT
Z71 4x4 with allstar package
5.3L V8 Flexfuel with 6 speed AT
Onstar / Sirius XM
Factory Tow Package
Electric Brake Controller
Silver Ice Metallic
265/65/18
Wifes Vehicle
2014 Kia Sorento EX AWD
3.3L V6
Toys
2007 Yamaha VStar Silverado
1086cc 45 degree vtwin
Grey and Silver
GPS positioning locator installed
Old 07-11-2011, 08:25 PM
Re: thumping sound in front driver side
2000 chevy silverado 2500 4x4 6.0L extended cab.... this has the auto, 4hi,2WD,4Low selector..... I do NOT use 4X4 on roadways unless completely covered in snow.
4x4Junkie
Onstar / Sirius XM
Factory Tow Package
Silver Ice Metallic
265/65/18
Wifes Vehicle
3.3L V6
Toys
Grey and Silver
Old 07-12-2011, 07:46 AM
j cAT j cAT is offline
what about the steering wheel ?
this can be axles if the steering wheel is not effected...
jack the front off the ground. then place wooded blocks under the lower control arms... with the cv axles straight rotate the hubs..
Old 07-12-2011, 08:56 PM
well there is no play what so ever in the steering wheel, and no vibrations. I removed the ABS sensors and the color of the grease is blue inside. i even took a very small clean screwdriver inserted into hole and tried to stir up another color, no other color appeared.
4x4Junkie
Onstar / Sirius XM
Factory Tow Package
Silver Ice Metallic
265/65/18
Wifes Vehicle
3.3L V6
Toys
Grey and Silver
Old 07-12-2011, 09:20 PM
it appears its time to focus on the axles condition, so i will post back info after straightening up the axle and again checking for wear.
4x4Junkie
Onstar / Sirius XM
Factory Tow Package
Silver Ice Metallic
265/65/18
Wifes Vehicle
3.3L V6
Toys
Grey and Silver
Old 07-13-2011, 07:31 PM
ok problem resolved, as was previously expected the problem was the wheel bearing........ with everything removed from hub including axle I still had no play in the bearing, out of curiosity I tapped the side of the hub with a hammer then and only then did the bearing start wobbling and moving freely when pressed against...
4x4Junkie
Onstar / Sirius XM
Factory Tow Package
Silver Ice Metallic
265/65/18
Wifes Vehicle
3.3L V6
Toys
Grey and Silver
Bad Sound Front Drivers Side???? bugsas99 Aurora 2 07-12-2011 09:13 PM
Vibrating/wobbling sound front drivers side wheel area DocShock Cavalier 7 03-14-2006 11:50 PM
annoying grinding sound up front drivers side joshmc Pick-Up 2 01-20-2005 08:48 PM
knocking sound in driver side wheel well beatybaby '97+ 4 12-23-2004 12:48 PM
wheel chirping and thumping sound under passenger side floorboard JackDaniels386 Taurus | Taurus Wagon 1 12-01-2004 12:51 PM
