Go Back   Automotive Forums Car Chat > Saturn > SC/SL/SW
Old 07-11-2011, 06:18 PM
xdanx25 xdanx25 is offline
2000 SW2 wheel bearing
just curious as how to replace it, or if its the same as the 98 version
Old 07-11-2011, 08:21 PM
speediva's Avatar
speediva speediva is offline
Send a message via AIM to speediva Send a message via Yahoo to speediva
Re: 2000 SW2 wheel bearing
Welcome to AF for starters!
I'm afraid I don't know much about this model, so I can't be of assistance, but hopefully someone with more expertise can share!
Like a boy - but BETTER!
2005 Subaru Forester 2.5X
1997 Honda Civic EX Coupe
Inform yourself:
AF User Guidelines
Old 07-13-2011, 12:41 AM
Ruley73's Avatar
Ruley73 Ruley73 is offline
It is the same as any 1998 or any 1991-2002 S-Series for that matter.
It is more difficult than most cars because the bearing and hub (two separate parts) need to be pressed off/on with a hydraulic press or with an appropriate hub puller. The hub gets pressed out of the bearing first then the bearing gets pressed out of the steering knuckle. There is a large snap ring on the inner side of the bearing holding it in place, so don't forget to remove that before trying to press it out of the steering knuckle.
For installation, the new bearing must be pressed into the steering knuckle first, then the hub gets pressed into the bearing. You can reuse the hub unless you see an obvious reason to replace it.
My rides:
2007 Chevy Equinox LT FWD
2018 Chrysler Pacifica Touring L
"If women don't find you handsome, they should at least find you handy!"
- Steve Smith (Red)
Wheel Bearing & ABS Light frehleycomet Venture 13 11-23-2013 10:27 AM
2000 Venture "buzzing" wheel bearing ? pjw73nh Venture 9 02-29-2012 07:23 PM
2000 Rear Wheel Bearing richamer1 Montana/Montana SV6 1 02-25-2008 12:04 PM
2000 Front wheel bearing & hub - My Experience ____ Windstar 1 02-20-2008 09:08 PM
2000 GT wheel bearing i think 00GT Grand Prix 23 04-25-2006 12:05 PM
