Old 07-11-2011, 03:38 PM
tbalonick tbalonick is offline
Question Carb Conversion
I have a 1981 Buick Regal V6 3.8L. It has a Rochester Quadrajet E2ME carb on it right now. This carbs been nothing but problems. I just rebuilt it which made the car go from sluggish and stalling to backfiring and running terrible on acceleration. Im almost positive the Mixture Control Solenoid is bad and the connector for the electronic choke is broken so that not even hooked up. Instead of going in and replacing all this or getting a new carb (which runs at about $500) and hoping that fixes it id rather just convert it to one of the old style carbs. How hard would that be to convert it to a non electronic carb? Whats involved? Thanks for the help, im not too familiar with carbs so any help is awesome!
Old 07-11-2011, 04:21 PM
Moppie's Avatar
Moppie Moppie is offline
Master Connector
Re: Carb Conversion
If you've just rebuilt the carb, what is wrong with replacing the Solenoid as well?
Old 07-11-2011, 05:45 PM
Re: Carb Conversion
Because I dislike this carb. Id rather just have a old vacuum carb on there. I could replace it but I dont currently have the equipment to test to see what the main causes are. I adjusted the idle so it idles much better now, but on acceleration it stalls and bucks... Id just rather replace the carb. So yeah...
Old 07-11-2011, 06:01 PM
Scrapper Scrapper is offline
AF Premium User
Re: Carb Conversion
i would check the jets also do you have them 1 and 1/4 ajusted out i do believe.
Old 07-11-2011, 06:02 PM
Moppie's Avatar
Master Connector
Re: Carb Conversion
Fair enough
I don't know a lot about American Carbs, I've only ever used Side drafts.
But, there are some guys around here somewhere who know more than enough, and should be able to help.
I'll see if I can rattle them up for you
Old 07-11-2011, 06:06 PM
Re: Carb Conversion
Ha, thanks for the help As for the jets, I do believe there adjusted, i never took them apart so im sure they aren't not adjusted, and i put a new float in the carb which is adjusted as well.
Old 07-11-2011, 06:20 PM
Moppie's Avatar
Master Connector
Re: Carb Conversion
If you didn't take them out, are you sure their clean?
As for being adjusted, you can't really know unless you check yourself
Old 07-11-2011, 06:29 PM
Re: Carb Conversion
Yeah i soaked it in carb cleaner and blew it out. I know its not a problem with the jets being clogged, its actually getting to much fuel cause its running rich, mainly cause somethings not adjusted properly and i think the MCS is broken. But i highly doubt its the jets.
Carb Conversion for Rabbit pickup wanted wcedgar Rabbit 2 10-29-2005 07:28 PM
XS Carb conversion 205will205 205 0 07-13-2005 08:08 PM
TBI to carb conversion on 88 model or similar?? 2shus Ram Pickup | Ram SRT10 6 04-07-2005 08:17 AM
Carb Conversion swedish Classic Cars 1 07-15-2002 02:20 PM
