Go Back   Automotive Forums Car Chat > Pontiac > Bonneville
Old 07-09-2011, 04:53 AM
wolfden6 wolfden6 is offline
2000 Bonneville ABS codes??
I have a 2000 Bonneville and just recently the anti-lock,trac off, and brake lights came on....Took it to our local tire shop and they scanned the car and these codes came up...Code C1214 & C1248.
Can anyone help point me in the right direction with this or had the same problem.
Thanks
Old 07-09-2011, 06:44 AM
procaddytech procaddytech is offline
Re: 2000 Bonneville ABS codes??
The C1248 just indicates that the Electonic Brake Control Module (EBCM) turned on the red brake light. It did this because of the C1214. C1214 description is ABS System Relay Contact or Coil Circuit Open. The relay is an internal part of the EBCM. If the code is cleared and returns during a function test, you will need an EBCM installed and programmed.
Old 07-11-2011, 06:03 PM
So the wierdest thing happened today....I drove into reno which is 40 miles from my house..all lights (ABS-Red Brake-Trac off) were on. I got in the car to head home and started the car and All the lights are off and have been off for the 40 miles home and I even went out and started it and drove it a few more miles and it looks like everything is fine...B
oy if this isn't weird
Old 07-24-2011, 04:03 PM
Hungrycat7's Avatar
Hungrycat7 Hungrycat7 is offline
I am having the same problem with mine. Every time I hit a bump it throws the lights on. Every time I shut the car off and start it up all lights are off until the next bump. I think it is a wiring issue to the wheel speed sensors.
Old 08-06-2011, 09:15 PM
Tech II Tech II is offline
With the key out of the ignition, disconnect the harness to the EBCM...check contacts for corrosion.....if ok, just reconnect and see if that solves the problem.....
abs pulsates over 45mph on 2000 bonneville schadd1971 Bonneville 8 10-19-2010 11:31 AM
2000 Alero 3.4 ABS light on, code c1265 skeeter123 Alero 8 01-26-2010 07:51 AM
2000 Bonneville ABS, Trac problem when turning jlemire Bonneville 1 04-06-2007 01:37 PM
2000 Rodeo ABS & Engine Trouble Codes jakob77 Rodeo | Passport | MU 1 03-03-2006 10:32 AM
2000 regal ABS codes t-bird1963 Regal 2 02-18-2005 08:42 AM
