Go Back   Automotive Forums Car Chat > Hyundai > Elantra | Avante
Old 07-08-2011, 02:56 PM
Neunundneunzig Neunundneunzig is offline
Clutch Problem on 2002 Elantra?
Hey guys, I started my day normally until I went to the garage to start my car. Upon entering the car, I noticed the clutch was feeling a bit strange. Disregarding this, I started my car and attempted to back out of the garage until I noticed I was unable to put my car into any gear.
The shifter goes through the gears without any problems while the car is off, but not while running, thus leading me to believe the clutch is to blame. I've also noticed the clutch feeling different for quite some time, though I shrugged it off as my own paranoia.
What do you guys think? The car is about nine years old with 56k miles
Old 07-08-2011, 09:05 PM
Moppie's Avatar
Moppie Moppie is offline
Master Connector
Re: Clutch Problem on 2002 Elantra?
G'day,
It's an Hydraulic type clutch, so the first thing to check is the fluid level in master cylinder.
This will be under the bonnet beside the brake fluid resevior
If the level is low, then top it up with brake fluid.
The clutch should now work again, but it does mean you have a fluid leak.
Usually it's in the slave cylinder, fortunately these are quick, cheap, and easy to replace.
If the level isn't low, it may still be the slave cylinder, but you will need someone to work the pedal while you watch the cylinder to see if it's moving and release fork.
If it is, then the problem is with in the clutch itself.
It's not unheard for the diaphragm on the backing plate to fail, or the disc to stick the flywheel, break etc.
That is a bit more involved to fix, as it does mean removing the gear box and replacing the clutch.
Old 07-08-2011, 09:10 PM
Moppie's Avatar
Master Connector
I found a great video on youtube showing where the slave and master cylinders are, how to replace them, and bleed the system:
http://youtu.be/vKV8a0QL5uk
2003 Forester transmission/clutch problem? JonnyU Forester 3 07-03-2011 03:49 PM
2002 Elantra GT - Clutch pedal has no resistance markag6 Elantra | Avante 0 08-13-2010 08:11 AM
clutch problem..i think bov3220 Engine, Transmission and Drivetrain 4 05-22-2009 12:17 PM
2002 elantra problem michael word Elantra | Avante 2 09-21-2008 03:33 AM
2002 Elantra clutch/tranny issue tvshooter Elantra | Avante 2 08-24-2007 12:58 PM
