Old 05-29-2003, 09:03 PM
spongerlbc's Avatar
spongerlbc spongerlbc is offline
Send a message via AIM to spongerlbc
Car wont start.....
Ahhhh crap my car wont start. I was at my friends for a bit, started my car and it ran for about 2 seconds before cutting out. It wont turn over, no clicking, no noises. All lights and the stereo all work. A few weeks ago my tachometer quit working (not sure if it has anything to do with this). I dont have time to work on my car till tomorow so does anyone have any good starts as to what could be the problem?
Old 05-29-2003, 09:37 PM
tbk49's Avatar
tbk49 tbk49 is offline
Send a message via MSN to tbk49
maybe ur alternator, im guessing
blah
Old 05-29-2003, 10:35 PM
johnb16a2's Avatar
johnb16a2 johnb16a2 is offline
Maybe the main relay?
Old 05-29-2003, 11:49 PM
jeef jeef is offline
Send a message via AIM to jeef Send a message via Yahoo to jeef
did you happen to try and jump the car? or push start it? the batt. could be dead enough it won't turn over but the lights and radio work... start with the free stuff and make sure the batt is good...
then if the car does run if you push start it and won't turn over i'd look into the starter... if it doesn't look into the main relay, wire connections and the distributer....
90- crx si w/ a D16a Vtec and a few goodies, oh and 60k miles on it heh
Old 05-30-2003, 01:45 AM
chopstick1981 chopstick1981 is offline
when my alternator went bad my tach sometimes would turn off also until one day i couldn't start my car either. But if that is the prob then your battery light should come on. Some auto part stores will check your alternator and other electrical stuff for free, you should find one of them
Old 05-30-2003, 03:09 AM
tbk49's Avatar
it is electrical probably so check ur fuses too, all of em, and get someone to test ur alternator and see if you have a spark from ur plugs
blah
Old 05-30-2003, 04:59 AM
RedRacerCivic's Avatar
RedRacerCivic RedRacerCivic is offline
Send a message via AIM to RedRacerCivic
check for corrosion on the battery terminals and inside the plug where the wire harness plugs into the alternator
-1991 Civic Si (Sold)
-1990 Accord EX(Sold)
-2000 Civic Hatch
-1998 Lexus SC300
Click here to see my Shoe!
Old 05-30-2003, 07:30 AM
redmanjd redmanjd is offline
im with jeef
95 b18b
new crank, eagle rods, je 10.5 : 1 pistons, 8lb flywheel, stage 3 act clutch, billet aluminium and urathane mounts, balanced rotating mass, 14.3 @ 93mph
New additions, teo4h turbo, ssautochrome turbo manifold, custom piping, turboxs bov, dsm 450cc injectors, greddy e-manage fuel controller 13.07 @ 107 untuned
Old 05-30-2003, 08:20 AM
cscott784 cscott784 is offline
Send a message via Yahoo to cscott784
check if you have enough gas. Also, check your starter.
Scott
