Go Back   Automotive Forums Car Chat > Toyota > Camry/Camry Hybrid/Vista
Old 07-07-2011, 05:28 PM
jeanmarie jeanmarie is offline
94 Toyota Camry is Overheating
My 94 Toyota Camry V6 LE is overheating; I've replaced the radiator, the radiator cap, the water pump, the timing belt, and the over flow tank. Still, after about 35-40 minutes of driving, the noise the car usually makes when I hit the gas is MUCH louder than normal and this precipitates the gauge going above the halfway point. I got the water pump done today and after about 40 minutes of test driving the car, it made that noise again, and after I turned the car off the over flow tank was boiling and a small amount of water had come out of the top of it. The first time the car overheated I didn't notice the gauge was above halfway until it was all the way on 'H' and I literally couldn't drive it anymore. I'm worried that doing that did something that permanently damaged the car.
Old 07-07-2011, 06:25 PM
FishFind FishFind is offline
One Hot Shot
Re: 94 Toyota Camry is Overheating
try new Thermostat
You may have killed the head gasket. Look for smoke from the tail pipe, or milkshake in the oil.
Old 07-07-2011, 07:16 PM
danielsatur danielsatur is offline
Do the coolant fans work proper? , check the fuse + relay.
Old 07-07-2011, 07:49 PM
The fan is running properly, a few people have said that it might be the head gasket, though the thermostat also has not been replaced. What's the likelihood that, considering the car's symptoms, that it is the thermostat? I'd rather have to replace that than the head gasket
Old 07-07-2011, 10:11 PM
Mike Gerber Mike Gerber is offline
AF -Advisor
If the thermostat was defective and sticking in the closed position, the car would overheat in just a few minutes; not 35-40 minutes.
Has a professional tech been doing all these repairs? Has the tech performed any tests to check for a bad headgasket? Assuming that it's not a bad headgasket and taking in to account everything that has already been done to this car, it may be that the entire cooling system is clogged. Has anyone suggested a backflush of the cooling system to get most of the crud out of it? How many miles are on this car?
Mike
Old 07-12-2011, 06:44 PM
One Hot Shot
Guess he fixed it?
Old 07-21-2011, 08:54 PM
jdmccright's Avatar
jdmccright jdmccright is offline
The RustBuster
Another possibility is that the valve that controls the hydraulic fluid that turns the fans, it's relay, or the coolant temperature switch has failed, most likely the latter. it is located at the bottom of the radiator near the center. When it fails, the circuit is stuck closed keeping the fans from running. Unplugging it will open the circuit and should turn them on. If this works, the switch is bad.
The V6 cooing fans aren't electric, they're hydraulic and the fluid is power steering fluid that comes from the PS pump. There is a control valve that regulates the flow to run the fans when it gets too hot. The temperature switch controls when the valve opens and closes and is a normally closed switch below operating temp.
Hope this helps!
Current Garage:
2009 Honda CR-V EX
2006 Mazda 3i
2004 Chevrolet Silverado 2500HD
2003 GMC Envoy XL
2000 Honda ST1100
2000 Pontiac Sunfire
Vehicle History:
2003 Pontiac Vibe AWD - 1999 Acura Integra GS - 2004 4.7L Dakota Quad Cab 4x4 - 1996 GMC Jimmy 4wd - 1995 Chevrolet C2500 - 1992 Toyota Camry LE 2.2L - 1992 Chevrolet S10 Ext. Cab 4.3L - 1995 Honda ST1100 - 1980 Yamaha XS400 - 1980 Mercury Bobcat.
Manual door lock wont stay unlocked! 95 Toyota Camry DerekDougherty10 Camry/Camry Hybrid/Vista 1 05-16-2011 05:13 PM
97 Toyota Camry Overheating nieve Camry/Camry Hybrid/Vista 5 07-04-2008 10:36 PM
1993 Toyota Camry Overheating When Ac Is On gus1963 Camry/Camry Hybrid/Vista 9 08-17-2007 12:29 PM
1992 toyota camry overheating Neonic Camry/Camry Hybrid/Vista 6 12-27-2004 04:16 PM
