Go Back   Automotive Forums Car Chat > Dodge > Ram Pickup | Ram SRT10
Old 07-06-2011, 10:42 PM
jgriner jgriner is offline
Cruse/ac wont stay steady
When I climb a hill or step on the gas, my ac vents change direction. They switch from blowing head on, to defrost. Also my cruse wont kick in extra gas to drive up hills.
Im assuming both the cruse and ac vents run off vacuum pressure, so I must have a leak, right? where do I start? how do I find the leak? Also I very dumb when it comes to engines and stuff (so English please lol)
98 dodge ram pickup quad cab 1500 5.2l
Thanks for all the help in advance
Old 07-06-2011, 10:49 PM
Tony Silva's Avatar
Tony Silva Tony Silva is offline
Re: Cruse/ac wont stay steady
A/C is electronically controlled so is the cruise. Sounds like you need to have your pcm checked out for deterioration.
Old 07-07-2011, 09:51 AM
jpb53 jpb53 is offline
It has a vacuum operated servo for the cruise which is under the battery. Acid will drip on the vacuum line a eat a hole in it. Follow the cable the goes forward from the throttle body.
The Following User Says Thank You to jpb53 For This Useful Post:
jgriner (07-08-2011)
Old 07-07-2011, 08:01 PM
thanks will check, is that the same line that connects to the ac vents controls?
Old 07-08-2011, 06:18 PM
Chris Stewart's Avatar
Chris Stewart Chris Stewart is offline
AF - Advisor
Sometimes a vacuum line will develop a crack that allows air into the system.
You might check those lines, fittings and the little plastic check valves.
1992 Bravada, 201K, stock
1997 Bravada, 101K, stock...was "called away"
"Cornbread Red", 2001 Dodge 2500,4X4,HO Cummins Diesel,QC,SWB,6spd.,Banks boost&pyro,US Gage fuel press.,Edge Drag Comp,4"exh.,cowl hood, bhaf, black Holley pump, 140gph...13psi WOT, Vulcan Big Line, kevlar/ceramic single disc clutch, cheapo fuel cooler, 8x.010" vco injector nozzles, Cat turbo 62-65-.70A/R, 497hp 1089 tq 8/25/14
Time to turn so's you don't burn.
The Following User Says Thank You to Chris Stewart For This Useful Post:
AC compressor making steady clicking sound mike561 Caprice 17 07-25-2010 09:23 AM
check engine soon stays steady, blinks periodically, rough idle, driveable? dacdd Intrigue 8 10-19-2007 11:33 PM
cruse control wont set ssigurdson '97 - '03 12 01-24-2006 08:29 PM
AC fan stays on Pumpkinfuel Bonneville 1 09-21-2005 02:32 PM
ac button stays on but no cool air on 95 mngrivera Grand Prix 2 06-28-2005 12:03 AM
