Old 07-06-2011, 04:20 PM
kurtl's Avatar
kurtl kurtl is offline
Send a message via ICQ to kurtl
1/12 Tyrrell P34 Monaco 77
I started with the roll bar to have to get the right shape, I extrapolated the 1/20er in part to 1 / 12 and I made a template that I have fixed on a cork plate.
With pins I was able to force the "Cold formed a roll bar to the desired shape.
As you can see the clip can be removed without problem ...
We continue with the oil reservoir, this had to be rebuilt since the 76th tank not under the narrow roll cage the '77 version takes place.
Again, I have extrapolated the 1/20er tank to 1 / 12 and transferred to a 0.5 mm thick plastic plate, cut out and glued together.
Lucky, it fits ... ... ...
Lg
Kurt
Old 07-06-2011, 10:57 PM
kurtl's Avatar
Re: 1/12 Tyrrell P34 Monaco 77
Left the Seat in 1/20 an right the converted in 1/12
Left the 77 Seat and right the 76 of Studio 27 Japan Transkit
The frontcover was cut
Lg
Kurt
Old 07-07-2011, 03:04 AM
flhansen's Avatar
flhansen flhansen is offline
Love it. Subscribed :-)
Flemming
Old 07-08-2011, 02:48 PM
kurtl's Avatar
In the area of ​​the front suspension, I mounted an extra plate on the Blue chassis top.
The cover of the original missing rivets have also been replaced by Resin rivets the accessory trade. Insgesamt sind es 132 Stück. In total there are 132 pieces.
By installation the plate was the front now too deep by 0.5 mm
The fixation was increased by 0.5 mm
On the covering were still additional 5 rivets used to mimic the bracket for the screen, this wind shield was only Ronnie's cockpit design.
And to be adjusted in that the 0.5 mm plate was affixed the fairing had to the new circumstances.
Currently, state
Lg
Kurt
Old 07-08-2011, 03:53 PM
robrex's Avatar
robrex robrex is offline
Plastic reworked to perfection! I'm watching this as well
Rob
Old 07-17-2011, 03:10 AM
kurtl's Avatar
It continues with the front stabilizer.
This was made from a 2mm rod from Evergreen.
The shifter I have made from wood
And some extras to share was more attached to the different
that's it
Kurtl
Old 07-17-2011, 04:54 AM
flhansen's Avatar
Nice! Like that wood shifter. Great detail!
Flemming
Old 07-19-2011, 04:15 PM
kurtl's Avatar
The next section, the brake ducts on the front axle
Great, now brings Studio 27 a Transkit on the market....... :roll:
The chassis plate was Painted with Tyrrell blue from Zero Paint
Much time I needed for the seat
The template produced by the seat of japan Transkit
Engine details are Ejan
Lg
Kurt
Old 08-21-2011, 03:34 PM
kurtl's Avatar
So folks,
this section with the small alterations to the Monaco '77 model are finished, from now on I have no longer even make parts * gg *.
Between the rear wing mounts there is an oil reservoir, the 77 containers is substantially different from the 76er version.
According to my research, I came to this result:
The rear wing mounts were a little Modified:
Modified left and right the original from the kit
And here the parts mounted Provisionally, some details are missing ... ... ..
Instantaneous overall impression:
the front brake ducts got a grid used
The exhaust pipe ends are bent outward at the 77 version
One Final Pass sample of the parts before painting
And here, in addition to the P76 prototype version
The front stabilizer was his connection to the chassis.
The rear wing holders are already finished and painted the brake lines have also been fixed.
Seat, fairing and front wings are painted already clear.
And the rear tires were labeled using a template.
Lg
Kurt
Old 08-26-2011, 06:53 AM
kurtl's Avatar
A small update
one screw and a line here because this is how the next steps from ... ...
there are still missing some hoses and cables ... ... ... ... ... ... ... ..
Lg
Kurt
Old 08-26-2011, 07:29 AM
hildengarde hildengarde is offline
Incredible !
What a fantastic work !
Old 10-12-2011, 12:25 PM
kurtl's Avatar
My 1/12 Tyrrell P34 Monaco GP 1977 is finished.
In this rebuild is not a Transkit, but it was many additional parts from different manufacturers used.
But much was also made ​​itself such as the struts on the front of the "nose" and the air contour sheet over it.
The rest is substantially known in the building report.
Fairing bolted like the original ...
Front tire label with 1 / 20 Rear template and sprayed each wheel became a valve ...
Lg
Kurt
Old 10-13-2011, 03:57 PM
John18d John18d is offline
Beautiful work on two great cars of the past Kurtl - Thank you for sharing these pictures and you techniques - John
Old 10-15-2011, 11:20 AM
Fmid Fmid is offline
Great work! Congratulations!!!!
Tameo 1/43 Tyrrell P34/2 1977 British G.P. Porsnatic WIP - Motorsports 9 02-27-2011 01:59 AM
1966 Honda S800 - Doyusha 1/12 edwing666 Completed Projects / Gallery 5 04-28-2010 09:35 AM
Tyrrell P34 Monaco GP' 77 (Tamiya 1/20) Anthony_RUS Completed Projects / Gallery 10 03-01-2010 05:35 PM
1/20 Tyrrell P34 Monaco Six-wheeler Rickard_Olsson WIP - Motorsports 7 04-21-2008 01:22 PM
Completed 1/12 Tyrrell ericweller Completed Projects / Gallery 14 04-22-2007 04:19 AM
