Go Back   Automotive Forums Car Chat > Toyota > Camry/Camry Hybrid/Vista
Old 07-05-2011, 09:31 PM
Oldriver Oldriver is offline
1994 Camry brake help
I replace the rear brake pads with Duralast Gold. I compressed the piston to swing the caliper back in place. But as seen in the picture, it stopped on top of the bushing where the 12mm bolt suppose to screw in.
Can I tap the bushing in, and if so what should I use?
Thank you
Howie
Old 07-05-2011, 10:30 PM
Brian R.'s Avatar
Brian R. Brian R. is offline
Resident Chemist
Send a message via Yahoo to Brian R.
Re: 1994 Camry brake help
You shouldn't have to move the bushing to replace the caliper. Try prying the caliper instead. The pads are probably a little off center and need to be compressed in the right direction. Make sure you've put the shims in correctly with only a light coating of grease.
Forum Guidelines:http://www.automotiveforums.com/vbulletin/guidelines.html
"What we've got here is a failure to communicate"
Old 07-06-2011, 11:15 AM
Hi Brian, I hope this other picture help explain. The pads are sitting flat against the disc, and the caliper has room for lateral movement. When I bring the caliper down, the bushing hangs out about a 1/16" preventing the bolt holes from lining up.
Can the bushing be tapped back - to the right in picture - so as to allow the holes to line up?
The Autozone sales guy told me I can tap it in, But I need a second opinion. Thank you
Howie
Click on pic to expand
Old 07-06-2011, 12:37 PM
Brian R.'s Avatar
Resident Chemist
How did the bushing get displaced from where it was when the caliper was previously installed? If you can get the bushing to move by tapping it gently with a hammer, with or without a punch, then it should be fine. If you have to work on it, you better rethink the situation.
Old 07-07-2011, 05:00 PM
I tapped it lightly and it moved. Probably got stuck from old tried-up grease.
Anyway, I was able to replace the pads and everything is working fine.
Not bad, cost me only $54 for parts.
Thanks again Brian.
Howie.
99 Camry Brake Power Booster going bad? ccyphers Camry/Camry Hybrid/Vista 4 03-18-2011 06:45 AM
1994 camry flooding out. help? kris10 Camry/Camry Hybrid/Vista 1 04-17-2010 07:09 AM
1994 safari brake pulling problem kcs213 M Bodies 4 03-24-2009 10:00 PM
98 toyota camry Brake help mchawkins Camry/Camry Hybrid/Vista 3 03-16-2009 08:24 AM
1994 Camry Front Brake question pooder Camry/Camry Hybrid/Vista 7 10-11-2004 11:17 AM
