Old 07-04-2011, 09:21 PM
jakeyf08 jakeyf08 is offline
o2 Sensor Testing Question
I pulled all 4 o2 sensors off of my 1996 Blazer because I was receiving a P0420 and wanted to check the sensors before testing the cat.
Two of the sensors were reading 3.6 ohms,
another 4.5,
and the fourth was 5.8
I also tested them by heating with a hand held propane torch. All of them reached .9xx volts and within seconds of removing the heat the voltage would drop to .01 volts or lower.
The question is could the sensor that was testing at 5.8 ohms be bad? From the information I received during research is that the sensors should be between 3 and 4.5 ohms. If there are any other problems that you may notice please feel free to let me know!
Thanks in advance.
Old 07-05-2011, 03:30 AM
Markb873 Markb873 is offline
Re: o2 Sensor Testing Question
Your voltages seem right which is what the computer reads, however it will compensate for some wear.
However did you check the O2 sensor for steady voltage while heating for two minutes?
and have you tried swapping them to opposite sides of the cat to see if the code comes back?
I also had that code come up one time based on a dirty MAF.
Hope that helps
-Mark
The cars on the lawn:
2000 Kia Sportage
1993 Chevrolet S-10 Blazer
1975 Radio Flyer Wagon
Old 07-05-2011, 05:46 PM
MT-2500's Avatar
MT-2500 MT-2500 is offline
AF - Advisor
another 4.5,
Thanks in advance.
You can read out 02 sensor voltage with a good volt meter.
Or switch sensors around.
But
The only way to test out sensors and cats is with a engine capable scanner read out on what sensors and cat is doing.
MT
Old 07-05-2011, 06:14 PM
danielsatur danielsatur is offline
DTC P0420 - The down stream H02 sensor signal on bank 1 told the ECU, that the catalytic converter isn't doing it's job.
99% That the cat is burned out.
1) Tap on the cat on bank 1 with a hammer and compare the sound with the cat on bank 2.
See OE Cats @ http://www.catalyticconverterwarehouse.com
The Following User Says Thank You to danielsatur For This Useful Post:
jakeyf08 (07-06-2011)
Old 07-06-2011, 12:01 PM
I was almost certain the cat was burnt out because I did start to hear a little rattling coming from it. I just want to make sure the sensors are good because I did have a bad misfire not to long ago and would like to solve the issue asap.
Old 07-06-2011, 03:23 PM
Did the Misfire turn into a backfire?
A rattle tells me the cats broken, and a empty tin can sounds like the the cat is blown out.
Old 07-07-2011, 03:45 AM
MT-2500's Avatar
AF - Advisor
Misfires and engine running problems are usually the cause of cat problems.
If you replace the cat make sure you repair the engine running and misfires problems or the cat will burn out again.
Cat rattle can be lose stuff inside cat or heat sheild rattle.
Cat not working or bad 02 sensor can cause 420 cat codes and also bad running engine problems.
Engine not running right is the main cause of cat failing.
Good Luck and let us know how it goes.
MT
Old 07-11-2011, 11:56 AM
I fixed the misfire a month or so ago. Ended up replacing the fuel injectors (had 225,000 miles on them) and the only code that was remaining was the p0420. A couple of days ago I bought two ac o2 sensors because there were two that were in very poor condition and didnt test correctly for voltage. I put the two new sensors in the y-pipe and reset the ecm. The ses light came back on within 50 miles and I checked the heat shield and found no visible problems. I pulled the cat off and replaced and the vehicle runs/accelerates much smoother than it did with the old cat on. Will post back if any codes return! Thanks for the help everyone.
The Following User Says Thank You to jakeyf08 For This Useful Post:
speediva (07-11-2011)
Old 07-11-2011, 12:04 PM
MT-2500's Avatar
AF - Advisor
You are welcome
And good Luck.
MT
Old 07-11-2011, 03:23 PM
speediva's Avatar
speediva speediva is offline
Send a message via AIM to speediva Send a message via Yahoo to speediva
Thanks for posting back with your diagnostics and solution!
Like a boy - but BETTER!
2005 Subaru Forester 2.5X
1997 Honda Civic EX Coupe
Inform yourself:
AF User Guidelines
Driving Test Exam question serge_saati COMPLETELY off-topic 4 01-12-2011 01:29 PM
Question: 2003 with W8-sensor problem? loocha '97+ 5 09-01-2009 09:00 PM
crank position sensor testing? c3RX9 General Discussion 4 03-27-2005 01:05 PM
knock sensor test bg862 Suburban 1 11-27-2004 11:18 AM
MAF Sensor Test Procedure??? 98 Blazer dean1969 Blazer 1 10-23-2004 02:41 PM
