Old 07-04-2011, 05:08 PM
compaqpunch compaqpunch is offline
No leaks and only 5 psi.... why?
Ok so the title is a bit missleading because i have yet to do a boost test but i do know ALL of the hoses have been replaced and checked well. Is there any factors other than a leak that would cause low boost? there is no boost controller. THANKS
Old 07-05-2011, 10:39 AM
Twizted_3KGT's Avatar
Twizted_3KGT Twizted_3KGT is offline
Re: No leaks and only 5 psi.... why?
How do you have no boost controller? Wastegates opening up would cause low boost.
1997 Mitsubishi 3000GT VR4 - 269AWHP/290AWTQ (Mustang Dyno) - [email protected] - 1.756 60ft. - [email protected] (Best TDO4-9B Time) - Driver Mod - IPS TD04-19TL - SPEC 4+ - Wiseco Pistons - 3SX Custom Forged Rods - PMP FMIC + Much More.
Old 07-05-2011, 12:42 PM
Girly VR-4 Girly VR-4 is offline
blown turbo will cause low boost, popped off hose as well.
www.groundzeroperformance.com
www.3swarehouse.com
1991 Stealth R/T Twin Turbo... sitting...
1996 Orchid Pearl Stealth R/T.... daily driver duty, 275k+ miles and counting!
1995 3000GT Spyder SL... being modified...
Old 07-17-2011, 11:47 PM
AutostradaVR4 AutostradaVR4 is offline
Did you by chance do a vac reduction? If you did and got rid of that mess of crap on the firewall, your only running wastegate presure (~6psi).
Formerly BlinkRA182
--VR-4-- --09 Lancer RALLIART-- --Me--
Psi CAL2800 3000GT/Stealth 5 05-17-2010 10:31 AM
'94 TS 3800: HUGE coolant leak - and other fluids jarl Trans Sport 23 10-31-2009 07:53 AM
cam seal leaks and leaks and leaks... carpenter_jai Metro 13 05-05-2009 02:27 AM
Why is it leaking and can it be fixed!! Help... Ro32 Bronco 1 10-22-2004 07:50 PM
If you're thinking about a RWP stage 3 turbo w/150+hp and 12 psi think again Kartoon 1 Lancer 1 12-03-2002 03:20 PM
