Go Back   Automotive Forums Car Chat > Chevrolet > Nova
Old 07-04-2011, 09:55 AM
big dwag big dwag is offline
Blow by on motor
I have a 350 stock motor, it was in my 77 nova i tool it out and put it in my 87 camaro. After a couple of weeks it started to leak from the front & rear seals, while it sat on the trailer ( not running). and it poured out while running. I took off the drivers side valve cover while the motor was running & it was blowing oil out of the vent hole between the # 1 exhaust & intake rock arms. I was told that one of the pistons had a hole in it, or the rings were broke. So i took it apart and found no holes in the pistons & no bad rings. so what do yall think.
Old 07-04-2011, 10:04 AM
jdl jdl is offline
Re: Blow by on motor
Do a cylinder compression test. Compare all cylinder readings.
Old 07-04-2011, 11:20 AM
maxwedge maxwedge is offline
A990 racer
A cylinder leak down test will see what and where the pressure is being lost, best way to test an engine's condition.
Old 07-04-2011, 04:53 PM
Yeah, but i had already torn the motor apart. I found the crank & rod bearings were worn, Crank was scared, & The screen on the oil pump was plugged up.
Old 07-04-2011, 05:30 PM
procaddytech procaddytech is offline
Agree. Do a compression test. If it is low, repair as needed. Did you re-ring the pistons and if so did you stagger the end gaps? If compression is ok, add a proper pcv system or repair the one that is malfunctioning.
Hatchback civic blows motor SRT-Wannabe Non Specific 0 10-15-2006 05:03 PM
2000 Camry Blow Motor Resistor Location alkemist Camry/Camry Hybrid/Vista 2 09-19-2006 02:35 PM
blowe motor lee101 Camry/Camry Hybrid/Vista 3 08-28-2004 02:46 AM
Supra blows motor on dyno trev0006 Car Videos 6 08-26-2004 04:09 PM
2000 Grand Prix Blow Motor summer78 Grand Prix 2 02-03-2004 06:03 PM
