Go Back   Automotive Forums Car Chat > Mercury > Mountaineer
Old 07-03-2011, 10:44 AM
ibalearner ibalearner is offline
Pre-ignition
2000 Mountaineer with 5.0 has pre-ignition rattle when pulling hills; severe when pulling a trailer or small boat. Have tried octane boost but no difference.
Suggestions?
Old 07-04-2011, 07:10 PM
shorod's Avatar
shorod shorod is offline
SHO No Mo
Re: Pre-ignition
Welcome to the forum!
Has it been doing this for awhile, or after filling up with fuel? Have you tried fuel from different brands? What grade of fuel are you using? Have you tried a different grade of fuel? And finally, when is the last time the truck had a tune up (fuel filter, air filter, spark plugs, spark plug wires, and even a MAF sensor cleaning)?
-Rod
Old 07-06-2011, 03:07 PM
Re: Pre-ignition
Thanks for your reply. Been doing this for a couple years now; very noticeable when pulling boat/trailer. Have not tried any fuel other than 87 octane (Shell, Texaco, Chevron). Complete tuneup as of one year ago (fuel filter, plugs, wires, air filter etc.). I would like to know how to clean the MAF sensor. Where is it located?
Thanks for your help. Much appreciated.
Steve
Old 07-06-2011, 07:36 PM
shorod's Avatar
SHO No Mo
Re: Pre-ignition
The MAF sensor is mounted in the intake air tube between the air filter and the throttle body. It is held in place by two tamper resistant Torx screws.
-Rod
Old 07-06-2011, 08:08 PM
Re: Pre-ignition
-Rod
-Rod, not sure if I'm replying to your last response correctly...Thanks again for your fast reply. I will attempt to clean the MAF sensor. Do I just remove it and clean the face?
Thanks, Steve
Old 07-07-2011, 07:02 AM
shorod's Avatar
SHO No Mo
Re: Pre-ignition
I used to clean the MAF sensor elements (very carefully) with brake cleaner. I'm not sure it's any different, but CRC makes a MAF Sensor Cleaner (smells like brake cleaner/electrical parts cleaner) which is what I use now. The elements are mounted with very fine wires, so be very careful to just spray the cleaner over them and not make contact between the cleaner's straw and the elements.
I don't really think cleaning the MAF will solve your pinging issue, but it shouldn't hurt anything to clean the MAF.
-Rod
FS: Pre-2003 Windstar new brake pres switch mundy5 Parts for Sale 0 03-23-2008 09:12 PM
Pre-runner chrome grill on non pre-runner anarchistchiken Tacoma 0 08-19-2005 12:25 AM
Pre-Run In Windrock warmonger Pathfinder | Terrano | QX4 | Xterra | Patrol | Safari | X-Trail 0 12-21-2001 04:57 AM
Pre Drilled Holes? Yes, No.... wallys99 Audio/Security 2 08-17-2001 03:48 PM
Fog lights pre-wiring: WTF? ales Maintenance 6 07-10-2001 02:56 PM
