Go Back   Automotive Forums Car Chat > Ford > E Series
E Series Forum covers questions and discussions regarding Ford E-150, Ford E-250, Ford E-350, and Ford E-450.
Old 07-03-2011, 12:13 AM
sj_32newnan sj_32newnan is offline
Question Replacing rear axel seal questions
I have a 96 e-250 that had a axel seal blowout. I need to know if I have to replace the bearing with the seal. Also, need to know what kind of gear oil to use in the rear diff. Thanks for the help and all that ya'll do on the website.
Old 07-03-2011, 12:35 AM
Tony Silva's Avatar
Tony Silva Tony Silva is offline
Re: Replacing rear axel seal questions
If it is just the seal that went bad then I wouldnt waste the time or money of replacing the axle bearing. The axle bearings would be one of the LAST things that would go bad on a ford vehicle. However, on some ford bearings, the seal IS part of the bearings. If there wasn't any humming noise coming from the bearing...just replace the seal.
Old 07-03-2011, 12:43 AM
Thank you. The seal is seperate from the bearing and the new bearing is $30. There was no humming and the seal busted when I was working on a differnt problem. Any idea on the gear oil.
Old 07-03-2011, 01:15 AM
Tony Silva's Avatar
Not sure on the gear oil, but I always go with "Lucas" additive. That stuff is awesome.
Old 07-03-2011, 01:18 AM
Thanks
rear axel seals jim72 Tundra 0 01-23-2006 07:58 PM
replace rear axle seals 97 f150 daveh815 F Series 3 10-29-2005 10:43 AM
91 blazer tahoe axel seal questions. djsteals Blazer 3 10-18-2005 07:18 AM
'01 4Runner rear axel seal repair Jack0715 4Runner/GX470 4 03-15-2004 02:59 PM
replacing rear main seal 95 Toyota 4Runner TimT 4Runner/GX470 1 11-11-2003 07:17 PM
