Go Back   Automotive Forums Car Chat > Pontiac > Bonneville
Old 07-02-2011, 06:47 PM
shelfont shelfont is offline
sudden transmission problem
Hi. I have a '90 Bonneville SSE and after coming to a stop at a red light on the highway, when the light turned green the car wouldn't move forward. There were no odd noises, the car had been in cruise control and there had been no problems up to that point. The car shifted crisply, there was no obvious slippage or hesitation going into gear.
I can feel the car engage in both drive and reverse, but it won't move at all.
Old 07-03-2011, 09:02 AM
maxwedge maxwedge is offline
A990 racer
Re: sudden transmission problem
Make sure there is no brake lock up, get the front and rear wheels off the ground see if the wheels turn freely, make sure the axle is not broken, basic tests, if all is ok it's done.
Old 07-04-2011, 12:53 PM
Thanks. The car rolled freely to push it off to the side of the road, and there were no odd noises that would indicate a broken axle. My understanding is that there are various electronic parts that are prone to failure in this transmission. Do you know of any specific things that I should be looking for?
What makes me wonder is the fact that this just happened with no warning. Came off cruise control and that was it.
Old 07-04-2011, 06:41 PM
A990 racer
There is no electrical component that would cause the trans not to go into reverse or drive. If it is full it is an internal issue.
Old 07-06-2011, 02:09 PM
Jrs3800 Jrs3800 is offline
Thats an internal issue... You may have blown a Lip seal and may not have enough pressure to apply the apply pistons or the clutches for that matter...
There are switches on the trans that the ECM uses to know that it can apply the TCC... The only electrical component on the THM440-T4( 4T60 ) is the TCC Solenoid... None of those will cause the trans to not apply... sounds like an internal issue...
Old 08-06-2011, 09:53 PM
Tech II Tech II is offline
Assume you checked fluid level and condition?
Alarmed by website highlighting Honda Odyssey Transmission Problems LibertyLoudSpeaker Odyssey 1 07-09-2010 03:03 PM
2003 GMC Sierra 1500 5.3 Transmission Problem kkaupang Sierra 1 05-19-2010 09:58 PM
1994 Prizm possible transmission problem theginchico Nova | Prizm | Spectrum | Sprint 0 04-11-2010 12:52 PM
1995 3000GT Turbo manual transmission problem rene8603 3000GT/Stealth 8 10-08-2009 03:49 PM
Transmission Problem SeanCL Cobalt 3 09-15-2009 08:16 AM
