Go Back   Automotive Forums Car Chat > Hyundai > Elantra | Avante
Old 07-02-2011, 06:19 PM
DeCardChef DeCardChef is offline
Car has lost power going up hills
My 2006 Elantra (automatic) has just recently lost power going uphill.
It has 39K miles on it. There are no error codes or check engine light warnings. I find it hard to believe after only 39k miles of use I would have a ring/valve problem.
Any suggestions to try before I have compression diagnostic done are welcome.
Thanks
Old 07-02-2011, 07:37 PM
inafogg inafogg is offline
Re: Car has lost power going up hills
Thanks
no i would'nt think rings/valves either.converter starting to clogg maybe
must be a lot of local driving 7k a year??been tuned lately air/fuel filter
maybe weak/low fuel pressure??
Live For Today
Yesterday is gone,
Tomorrows are'nt promised.
Old 07-02-2011, 07:39 PM
danielsatur danielsatur is offline
Have a back pressure test done on your catalytic converters.
A pugged CAT would cause lost hp.
The Following User Says Thank You to danielsatur For This Useful Post:
DeCardChef (07-04-2011)
Old 07-03-2011, 12:00 AM
Tony Silva's Avatar
Tony Silva Tony Silva is offline
danielsatur is correct...probably faulty catalytic converter(s)....they are "honeycombed" shape inside...real intricate!!! Do you hear any "hissing" coming from under your car as you accelerate? Pepboys can do the test. But if it were my car, I would disconnect the exhaust system in it's different sections to narrow down the possible problem myself. first I would remove the muffler, take it for a test ride. If it still had no power, I wiould move up the pipe system working closer and closer to the motor...removing whatever I came to. muffler...catalytic converter...exhaust preheater...
The Following User Says Thank You to Tony Silva For This Useful Post:
Old 07-04-2011, 03:21 PM
relatively low mileage but not a lot of stop and go. had 30K maintenance at Hyundai dealer in Rhode Island before moving to Arizona. runs fine and smooth. just not enough oomph going up hill. Checked the air filter, not dirty at all.
Will see what a local autmotive repair shop says.
Thanks
Old 07-04-2011, 03:50 PM
Moppie's Avatar
Moppie Moppie is offline
Master Connector
Thanks
Let us know what he says, I would be surprised if its a clogged cat with so few miles on it.
Does it just lose power going up a hill, or does it miss fire as well?
Often these sorts of problems are ignition related as they only show up under load.
no power up hill BeatleBaily S-10 4 02-17-2011 05:23 PM
Car just lost power while driving (0 RPM) mitsman123 Engineering/ Technical 8 12-01-2006 08:40 PM
My Car has got to go dwaynebmw 5 Series 0 03-24-2005 12:57 AM
car has lost its power PotIsYourFriend Alero 5 06-17-2004 07:54 PM
Car has less power & makes a slight clanking noise. Basick Cutlass Series 0 03-02-2004 01:21 PM
