Go Back   Automotive Forums Car Chat > Honda > Civic | CRX > '71-'87 Civic | CRX
Old 07-02-2011, 10:57 AM
US25076 US25076 is offline
Unhappy 1987 Civic Carburettor
Does anybody has simple intructions as to how to eliminate the vacumm hoses on the 1300ci engine. What vacumm hoses to plug and where to connect the necessary ones. My vehicle vacumm hoses were disconnected and it will not idle, It'll run but not idle. This vehicle is used mostly on a farm, no much highway at all.
Old 10-24-2011, 09:55 PM
aquarius's Avatar
aquarius aquarius is offline
Re: 1987 Civic Carburettor
oh man i cant remember which ones you need and not wish i could help honestly i woudl recommend upgrading to a weber carb runs soo much better unless your in cali then i guess thats not an option
Wheels spin tires burn. Racing!!!!
Old 11-07-2011, 09:10 PM
87Wagovan 87Wagovan is offline
This may be a bit late but...fyi
This is a pic of the correct routing:
http://www.hondaautomotiveparts.com/...TUBING+%281%29
HOLY intimidating!!!!! I have a 1500 and it is easy in comparison.
Really you only need the one vacuum canister on the left(driver side) and the vacuum advance on the distributor. However this and the thermo valves on the intake housing can be leaking vacuum enough to stall the engine at idle and will run rough otherwise.
canisters should not leak vacuum at all or very very slowly. The valve (next to the carb inside the air filter) should not leak when warm or cold. ALSO be sure the vacuum booster for the brakes is not leaking too!
1987 Civic/CRX HF HELP jessenichols1991 '71-'87 Civic | CRX 0 05-01-2010 07:54 PM
1987 Civic Sedan bigboy_al_1982 '71-'87 Civic | CRX 4 06-11-2004 06:56 AM
1987 civic wagon problems snowdog '71-'87 Civic | CRX 7 04-27-2004 07:50 AM
FS: 1987 Civic/CRX 3-Spoke Steering Wheel acid.nightmare '71-'87 Civic | CRX 1 06-26-2003 10:24 AM
