Go Back   Automotive Forums Car Chat > Ford > Explorer | Explorer Sport Trac
Old 07-01-2011, 12:19 AM
Hntingwolf Hntingwolf is offline
Fuel pump & ABS light
About a month ago my ABS light would blink and sometimes stay on and sometimes turn off. I'm not sure if it's related or not, but after a week or so with the ABS light my fuel pump stopped turning on. I checked the fuses, the relay and the pump and I had a mechanic double check me. We both came to the conclusion that the fuses were fine, the relay was fine and that the pump was shot as it wasn't turning on when I turned the key on. I replaced the pump a few days ago and low and behold.....it still doesn't turn on. Any suggestions would be greatly appreciated.
Old 07-01-2011, 12:26 AM
Tony Silva's Avatar
Tony Silva Tony Silva is offline
Re: Fuel pump & ABS light
You gotta narrow it down...first clean all the ABS sensors and see if that don't take care of the abs problem. No biggie here, just 10mm bolt's...even though I don't know what year or type of car you drive...POST IT!!!. I work at a dealership for engine management...post the year, make and model of your car.
The Following User Says Thank You to Tony Silva For This Useful Post:
Hntingwolf (07-17-2011)
Old 07-01-2011, 05:12 AM
Yup you can definately tell I posted in the middle of the night. Sorry about that. My vehicle is a 2005 Explorer Sport Trac with about 68000 miles.
Old 07-01-2011, 06:43 AM
shorod's Avatar
shorod shorod is offline
SHO No Mo
Do you have a scan tool or test light? Have you checked the fuel pump inertia cutoff switch? Is the "Security" or "Theft" light rapidly flashing when you attempt to start the truck?
There's a 20A fuse in the Battery Junction Box that should have power to and through it at all times. It will either be fuse F1.5 or, in "late production" vehicles, F1.30. This fuse provides power to the fuel pump relay in the Battery Junction Box. The fuel pump relay should be energized when the key is turned to "Run" (power provided through fuse F1.40, 15A) via the PCM Power relay. The switched side of the PCM Power relay is powered via fuse F1.3 (30A) also in the Battery Junction Box. The fuel pump relay should provide power to the inertia cutoff switch. If the switch is closed and working, along with the rest of the wiring between the switch and pump, the power will go through the switch to the fuel pump driver module. The fuel pump driver module is actually what will then provide power to the fuel pump. The driver module is switched by the PCM.
-Rod
The Following User Says Thank You to shorod For This Useful Post:
Wheel Bearing & ABS Light frehleycomet Venture 13 11-23-2013 10:27 AM
2000 Sonoma Replaced fuel pump ????????? cortervette Bravada 8 12-22-2010 10:42 AM
91 corsica 3.1 fuel pump not pumping miecow Corsica 3 05-04-2009 11:39 PM
Help with Fuel Pump Resister Relay bbaker1985 Grand Prix 1 03-28-2009 09:14 PM
gtp fuel pump? finkk Grand Prix 9 03-13-2009 08:04 AM
