Go Back   Automotive Forums Car Chat > Chevrolet > Impala | Impala SS
Old 06-29-2011, 04:37 PM
2011Pali 2011Pali is offline
Muffler Rattle?
Hi,
I have a 2011 Impala with 10,000 miles on it. Recently, something started rattling from the undercarriage when going over bumps. It is a high pitch rattle like a trailer when it goes over bumps. I have taken it to two chevy dealers and they said that the muffler was damaged, that it hit something and was pushed out of place. It was also missing a clamp which they reinstalled. They recommended a new muffler and said all other suspension components were fine (which I am doubting since one of them missed the missing clamp in the first place).
Question: Is there anything inside the muffler itself that could be causing the rattling?
Any advice you could give me would be greatly appreciated.
Old 06-29-2011, 10:35 PM
oldblu65's Avatar
oldblu65 oldblu65 is offline
Re: Muffler Rattle?
The muffler will have baffles inside but ( since it's a 2011 model ) I doubt the muffler itself is the problem . Exhaust systems generally are connected to the vehicle utilizing rubber mounts ( to lessen the noise and vibration ) , likely you have a broken or missing rubber mount causing the exhaust system to move excessively and hitting the bottom of your floor pan .
" Sometimes I grow so tired "
Old 06-30-2011, 02:24 PM
j cAT j cAT is offline
Re: Muffler Rattle?
Originally Posted by 2011Pali View Post
Hi,
these mufflers have internal baffles. if the muffler has a dent on the exterior this can cause these internal metal baffles to break off , and rattle..my concern is this can restrict the exhaust, also this will wear a hole in the muffler shroud..they should replace the muffler on warrantee, since a missing clamp caused the muffler to fall down...if you hit something and this all occured , then it would be best to go to a muffler shop and replace it..dealership will cost too much ! get stainless steel only.......
Old 06-30-2011, 02:58 PM
danielsatur danielsatur is offline
Re: Muffler Rattle?
Don't forget about the warranty.
98 Golf Muffler rattles after tow hitch install flutterbyegirl72 Golf 0 06-05-2007 02:39 PM
Flowmaster Muffler Rattle TwentyPints Silverado 25 08-21-2005 03:49 PM
Muffler Rattle D17A1R '88 - '91 Civic | CRX | Wagon | Shuttlee 2 10-07-2004 05:32 AM
muffler??? rattles when i rev..... housy_bigmike Camaro Discussions 4 05-02-2004 11:59 PM
