Go Back   Automotive Forums Car Chat > Ford > Ranger | Courier
Old 06-28-2011, 11:36 PM
jg65483 jg65483 is offline
Send a message via Yahoo to jg65483
Unhappy flooding
my 94 rannger 4.0l just flooded spewed gas and oil all over. will not start over almost got fire. just asking any ideas why and how?
Old 06-29-2011, 06:17 PM
mcmalloy mcmalloy is offline
Re: flooding
Fuel pump should only stay on for a few seconds when you turn the key on the first time . if it stays running then you ether have a short or the relay is stuck.try to disconnect the relay and start it,
Old 07-01-2011, 09:01 AM
Earlyboomer Earlyboomer is offline
Re: flooding
I had this problem myself. It was a pinhole in the diaphrm of the fuel pressure regulator. (The pinhole was miniscule, I ground off the crimped rim of the regulator to do a post mortem after installing the new regulator.) Take the vacuum line off of the regulator, the other end of this line is connected to the intake manifold, and if there is any smell of gasoline in this line, the regulator is bad. The regulator has a micro-ground flat pressure type valve inside on the fuel rail side, operated by the diaphram, and a hefty spring is on the other side of the diaphram to modulate the fuel pressure, using the vacuum of the engine. With a rupture of any size in the diaphram, that little vacuum line will pour a surprising amount of fuel into the intake. I had gasoline all over the garage floor in no time at all while trying to figure out what was going on. It was dangerous and I jumped to get the water hose and hose it down. This is nothing to mess with, hope this helps.
The Following User Says Thank You to Earlyboomer For This Useful Post:
jg65483 (07-01-2011)
Old 07-01-2011, 01:38 PM
Re: flooding
It worked thanks alot.
is my truck a flood truck? dearidiot Ram Pickup | Ram SRT10 3 02-04-2013 11:51 AM
1994 camry flooding out. help? kris10 Camry/Camry Hybrid/Vista 1 04-17-2010 07:09 AM
1990 Ford F150 - Flooding? mizshadow420 F Series 1 02-04-2010 08:03 PM
Because I can flood with the best of them YogsVR4 COMPLETELY off-topic 14 11-13-2001 09:28 AM
60 second flood control.. LostBoyScout Hot and Not 8 02-10-2001 02:31 PM
