Old 06-27-2011, 08:06 PM
mrstg65 mrstg65 is offline
sudden major coolant leak 3.1 litre SE
Hello,
1999 Grand Prix SE 3.1 litre engine 172,000 miles. The car suddenly started dripping coolant from the passenger side rear engine area. I have been watching the car closely since changing the water pump last week and until today absolutely no coolant leak. The leak is pretty bad when the the car is running. I brought it into the local pep boys for a diagnosis. They are saying that antifreeze ate through the timing chain cover and it needs replacement. They want a lot of money to fix and cannot even give me a price for the cover because it is a dealer part.
I read on another post about plastic elbows behind the tensioner that sometimes fail and can result in this type of leak. My question is do these exist on the 3.1 engine or is it just the 3.8 that has this problem.
Any thoughts are appreciated.
Old 06-27-2011, 09:32 PM
olopezm's Avatar
olopezm olopezm is offline
Send a message via MSN to olopezm Send a message via Skype™ to olopezm
Re: sudden major coolant leak 3.1 litre SE
Hi,
I've never seen a 3.1 engine so I don't know if it has the plastic elbows too. But I think the Lower Intake Manifold gaskets might be your problem.
Look under both heads to see if the coolant is coming out from there. Did you inspect yourself around the timing cover?, your problem might only be the gasket since there is no reason for the cover to start chewing itself.
Oscar.
1995 Lincoln Town Car 4.6 Signature
1997 Pontiac Grand Prix GT 3.8
2000 Ford Windstar SE 3.8
The Following User Says Thank You to olopezm For This Useful Post:
mrstg65 (07-10-2011)
Old 06-27-2011, 09:49 PM
Thank you for the quick reply Oscar
It is not leaking that high up on the motor, and it is only dripping from the rear of the passenger side. Both heads are totally dry.
It is hard to see exactly where the drip is coming from..that's why I took it to the shop. I am suspicious of their diagnosis because they also want to replace one valve cover gasket for almost $400.00. They do not specify which one. They also recommended changing the water pump, which is not leaking and appears new...I replaced it last week.
Old 06-27-2011, 10:40 PM
inafogg inafogg is offline
you need to get out of that shop!!!
i dont think the elbows are used on the 3.1 but not positive
i'd have the system pressure tested by a well known shop should'nt
be to tuff finding under pressure
400 for valve cover gaskets??? sorry 1 cover gasket?!$#%&*%%
Live For Today
Yesterday is gone,
Tomorrows are'nt promised.
The Following User Says Thank You to inafogg For This Useful Post:
olopezm's Avatar
It sounds to me like they are trying to steal money from you or they are just guessing.
I remember seeing a post about a common leaking point on the 3.1 engines. I'll see if I can find it for you and post it here.
Oscar.
Old 06-28-2011, 10:23 AM
GTP Dad GTP Dad is offline
Pontiac Guy
Are you certain that the coolant is coming from the engine. The drain for the heater core is located on the firewall on the passenger side of the engine. The leak would be worse when the engine was running and would stop when it wasn't except for a few drops. Check the area along the firewall on the passenger side to see if that is where the leak is coming from.
The Following User Says Thank You to GTP Dad For This Useful Post:
Old 06-28-2011, 10:46 AM
Yes it is coming from the timing cover I saw it with the car on a lift. I talked to the head mechanic today and he redid my estimate ( there is no reason to replace the valve cover gaskets to correct this issue or replace a brand new water pump.) As Oscar stated it is probably not the cover itself but the gasket that is leaking.
Old 07-10-2011, 05:43 PM
The only problem was the gasket itself not the cover. A very sudden failure as I had been watching the car closely for leaks after I did the water pump and it was bone dry for a week. The shop fixed it for a reasonable price after I talked to the boss. Would have posted back sooner but I just got back from vacation. Thanks to all for the replies.
1991 Cutless supreme 3.1 stalling mandude Cutlass Series 9 02-06-2015 01:16 AM
'94 3800TS: power steering and coolant leaks jarl Trans Sport 1 08-03-2010 05:02 PM
'94 TS 3800: HUGE coolant leak - and other fluids jarl Trans Sport 23 10-31-2009 08:53 AM
3.1 interchange info please. Ponyak Grand Prix 2 06-08-2009 11:58 AM
98 Grand Caravan 3.3L Coolant Leak hooperkj Caravan | Voyager 4 04-22-2009 05:17 PM
