Go Back   Automotive Forums Car Chat > Chevrolet > Malibu
Old 06-27-2011, 06:26 PM
hotpipes hotpipes is offline
Correct ABS resistance reading
My 2002 Malibu needs a Bearing hub with the anti locking break sensor built in to it. I need to check it with my ohm meter to see if it is the right front or left front sensor that is bad. Dose any one know what the resistance reading should be on these sensors?
hotpipes
Old 06-27-2011, 06:39 PM
maxwedge maxwedge is offline
A990 racer
Re: Correct ABS resistance reading
Around 1150 ohms at room temp.
The Following User Says Thank You to maxwedge For This Useful Post:
hotpipes (06-27-2011)
Old 06-29-2011, 03:24 PM
I have checked the right and left ABS sensors the right reads 1135 and the left reads 1104 the right one is about 27 months old and the connections are shine clean on both of them I checked the break fluid and that is up to max. Do you think that left one reads to low and needs to be replaced?
hotpipes
Old 07-09-2011, 08:20 AM
Since we talked last I had the the ABS scaned and found that the right front sensor with bearing was not giving the pulls needed to turn off the light. That bearing and sensor is just over two years old. I guess even with a good resistance reading the sensor can be bad
hotpipes
Wheel Bearing & ABS Light frehleycomet Venture 13 11-23-2013 10:27 AM
Help with Fuel Pump Resister Relay bbaker1985 Grand Prix 1 03-28-2009 09:14 PM
2006 4.2l f-150 abs? redka88 F Series 1 02-22-2009 10:29 AM
Coil Resistance Reading citydragon Camaro Discussions 1 06-19-2006 12:42 PM
ABS Code Reading kernow1 Jimmy 1 06-17-2006 10:13 PM
