Need Help. P0740
I found many threads on this and know my problem is the TCC Solenoid failure.
Noone says what solenoid is the problem? There is a regular TCC solenoid, A tcc Lock-up solenoid. one for shifting up and one for shifting down. what one do I need to replace? ![]()
Re: Need Help. P0740
My Blazer has thrown a PO740 code & it turned out to be the valve body needed to be reprogrammed. Chevy 4L60Es have a built in valve body failure. GMs answer was a new valve body which in time did the same thing. Any good tranny shop will be very familiar with this & they have found a permanent fix, provided the torque converter isn't burned up.
Sometimes if you clear the code you may find the problem fixes itself. At least for awhile My first code came a year ago & never had another problem until a month ago when I had the valve body redone. Common condition of a PO 740 code is a hard 1-2 shift & & overdrive not working but sometimes. For what it is worth. |
hrms I am not sure about the overdrive?.I will see if it works
Has code been cleared and drove to see if it comes back? Codes do not say replace part but do say to check it out. Start with going threw the repair flow chart for the code.
A hint on code P0740.
Code 740 says you have a open or shorted circuit to TCC solenoid. Circuit refers to the wiring or plugin.
Yep. P0740 is an electrical performance DTC, not a valve body concern. You know the power is going into the trans ok or you would also have DTC's P0753, P0758, P0785, and P2761. The fault is either an open solenoid (which requires a complete internal trans harness) or a fault with the control circuit from the PCM to trans or within the PCM. The solenoid resistance should be 21-33 ohms measured from pins T & E on the trans side with the connector unplugged.
I will check the pins. How do I know what pins are T,E is it coded?
It is a 1998 blazer 4dr 4x4 180,000 4.3L trans is the 4t06E i think I cant find the paper that has the info. I have had the code cleared 2 times. It comes back the very first time I turn the key and only about 2seconds after. After some looking around I found the answer to this question. here is a link for any future people with this problem. http://www.hotrodders.com/forum/atta...chmentid=52719 http://www.youtube.com/watch?v=rp7lz...yer_detailpage Last edited by FishFind; 06-29-2011 at 03:27 PM. |
also does anyone have a flow chart for this? I looked in my Haynes and it just tells me what the code is and to take it to a dealer. I can't find any info on the wires or how to test them
I have the pan off and have access to all the solenoids. Can you tell me what pins are T&E so I can test them before I put the pan back on? All the wires in the pan look good. I see no kinks or anything like that I unplugged every one and plugged back in tight to see if maybe it was loose.
The fluid in the pan did not look all that great. has a layer on the bottom of like metal dust. It sticks to a magnet. It is about a thick as a peice of paper. The filter in it was a Filtran Filter. Is this OEM from 1998
Where everyone go that was helping me.
here is what I did. I checked T&E reading was good. I checked all the other solonids also, all checked out. Took it for a drive after I changed the fluid and filter and cleaned all connections. It now seems to me to drive fine. No loss of power at takeoff, I got it up to 70mph and it was at 2,100 RPM. Is that good?? One thing I notice is that when I do 4X4 low. it engages at about 1,500 RPM and does it with a little jump. IS THAT NORMAL??? I never had a 4X4? The lights that tell me if I am in 2x2 4x4high and 4x4 low don't always light up????? I also noticed that the gas gauge started jumping and it did not do that before? does that aim at ignition switch?? I was told the fuel pump is new so I am guessing not the sending unit. My check engine light is still on but may need to be cleared first before it may go away. Anyone that can answer any questions please do. I am sitting not knowing what to do untill I hear what to do from someone. |
Ok, Gonna take it in to get tested to find what is wrong.
I left because I told you what happened to me when 3 times I had a PO 740 code that was fixed by a tranny shop after the third light, but what would they or I know. They have only been in the tranny business for 30 years. Build race transmissions & custom billet converters, Along with a full line of custom Diesel transmissions & converters.
This is a problem where it would be much easier to have the vehicle in my bay on a lift to accurately diagnose. I can send you flowcharts if you want, but a good transmission and electrical technician may save you time and money in the long run. I don't mean that as an insult but good technicians are hard to find, and if you can find one locally take advantage of the opportunity. If you happened to fix it by moving connections around the check engine light will turn off after 3 consecutive trips without a failure reported.
yeah if you can send me your flow chart that would help alot. Ill pm my e-mail
