Go Back   Automotive Forums Car Chat > Chevrolet > Equinox
Old 06-26-2011, 12:00 AM
trs's Avatar
trs trs is offline
head light adjustment
i have a 2008 chevy equinox 3.4l, i installed hid lights , how do i adjust the lights down alittle, where is the adjustment screw.
thanks
tom
Old 06-26-2011, 12:06 AM
Ruley73's Avatar
Ruley73 Ruley73 is offline
Re: head light adjustment
thanks
tom
There is a vertical adjustment screw. However, it is not labeled at all and does not tell you which direction to turn the screw to move the headlamp upward or downward. You don't need to remove the headlamp or need any special tools to make this adjustment. All you need is a regular #2 phillips screwdriver with a reach/length of about 4 inches. If you look just to the outside of the inner screw that holds the headlamp in place, you will see an opening where you can insert the screwdriver.
Hold the screwdriver in firmly and turn the screwdriver clockwise to move the headlamp downward or counterclockwise to move the headlamp upward.
I've attached a couple pictures below to help illustrate this.
My rides:
2007 Chevy Equinox LT FWD
2018 Chrysler Pacifica Touring L
"If women don't find you handsome, they should at least find you handy!"
- Steve Smith (Red)
1996 over head light cratercmc 1st Gen 95-99 5 04-23-2010 02:27 PM
'95 Sidekick JX wiring problem, park lights Bdamdifino Sidekick 0 12-05-2009 04:25 PM
How to adjust valves? lazerphreak Engineering/ Technical 1 05-08-2009 06:22 PM
99 Sunfire Dash Light & Radio Lights turn off when you turn on head lights fathershrubb Cavalier Problem Diagnosis 5 04-20-2009 04:26 PM
93 head light adjustment ss_termite Camry/Camry Hybrid/Vista 0 03-02-2004 06:26 PM
