Go Back   Automotive Forums Car Chat > Toyota > Camry/Camry Hybrid/Vista
Old 06-24-2011, 04:29 PM
AvalonJohn AvalonJohn is offline
Oil Viscosity ..... Which One
Have a 2009 Camry LE with 2.4 engine. I need to change the oil. Oil cap says 0-20W, but I was wondering if that is really the best oil for my engine? Seems a little light and I was thinking a Synthetic 5W-30 would provide more engine wear protection. I've hear reports that the manufactures specify the 0-20W and 5W-20 because it increases the gas milage of the cars which is the real reason they say to use those oils and a 5W-30 would actually provide better protection. Anyones throughts?
AJ
Old 06-24-2011, 06:07 PM
Mike Gerber Mike Gerber is offline
AF -Advisor
Re: Oil Viscosity ..... Which One
I would use what Toyota recommends; that is 0W-20 or 5W-20. I use the 5W-20 dino on my 07 XLE with the 2.4 liter engine. I notice that I consume about 1/2 quart of oil every 3000 miles, which I contibute to the lighter weight oil. I don't consider this an excessive amount of oil consumption.
Mike
Old 06-25-2011, 02:40 PM
Brian R.'s Avatar
Brian R. Brian R. is offline
Resident Chemist
Send a message via Yahoo to Brian R.
Stick with Toyota recommendation. Higher viscosity oils don't provide a meaningful increase in lubrication protection. The tough job for oil is on the cylinder walls and cam lobes. Viscosity has no influence on the quality of the high pressure additives needed for lubrication of the important wear points.
Forum Guidelines:http://www.automotiveforums.com/vbulletin/guidelines.html
"What we've got here is a failure to communicate"
Old 07-11-2011, 09:31 AM
jdmccright's Avatar
jdmccright jdmccright is offline
The RustBuster
FYI, the lower viscosity is the result of Toyota wanting to improve fuel economy. In a nutshell, lower viscosity oils are easier to pump through the engine's passages with less pressure loss. That plus advancements in surface treatments translates to better fuel economy through lower parasitic losses internally.
Current Garage:
2009 Honda CR-V EX
2006 Mazda 3i
2004 Chevrolet Silverado 2500HD
2003 GMC Envoy XL
2000 Honda ST1100
2000 Pontiac Sunfire
Vehicle History:
2003 Pontiac Vibe AWD - 1999 Acura Integra GS - 2004 4.7L Dakota Quad Cab 4x4 - 1996 GMC Jimmy 4wd - 1995 Chevrolet C2500 - 1992 Toyota Camry LE 2.2L - 1992 Chevrolet S10 Ext. Cab 4.3L - 1995 Honda ST1100 - 1980 Yamaha XS400 - 1980 Mercury Bobcat.
Old 08-27-2011, 01:11 PM
salesmantony salesmantony is offline
AJ
I accidentally put 5W-30 in my wife's 2007 camry with the same motor as yours. When I changed the oil after 5,000 miles (per the manual), it was noticeably dirtier and thicker than previous oil changes. I went back with the correct 5W-20.
which engine oil viscosity? outdoorman General Discussion 1 10-20-2010 11:14 AM
Oil Filter, Which one? old_master M Bodies 4 01-11-2006 10:21 PM
Oil Filter, Which one? old_master Blazer 4 01-07-2006 10:44 PM
Oil Filter, Which One? old_master M Bodies 0 01-07-2006 07:45 PM
Oil Filter, Which one? old_master Jimmy 0 01-07-2006 07:41 PM
