Old 06-23-2011, 03:46 PM
jseaward jseaward is offline
Remote Keyless Entry suddenly stops working after 171/174 fix
Hi,
I did the 171/174 fix today on my 2002 Windstar, following the Leckemby instructions.
That went well and the engine now idles well.
Unfortunately, my keyless entry fobs no longer do anything. They both suddenly stopped working at the same time. I have followed the reprogramming instructions in the manual, switching on and off 8 times until the locks close & open but pressing buttons on the fobs doesn't do anything even at this programming stage. It is unlikely to be the batteries in the fobs as they both stopped working at exactly the same time.
I guess there is a problem with the keyless entry receiver / antenna / module. Do you have any suggestions about whether I could have accidently dislodged an important wire during the 171/174 repair and how to identify where the problem is?
Thanks,
James
Old 06-23-2011, 08:22 PM
Windstartled Windstartled is offline
Question Re: Remote Keyless Entry suddenly stops working after 171/174 fix
Please forgive my ignorance but what's the 171/174 fix?
Old 06-24-2011, 05:35 AM
phil-l phil-l is offline
Powertrain error codes P0171 and P0174 are commonly caused by the infamous isolator bolt problem on '99+ Windstars. The fix is best - and most famously - written up here:
http://leckemby.net/windstar/windstar01.html
jseaward: Sadly, your diagnosis is likely correct - but I don't know of anything immediately obvious that would have been dislodged by work typical of the isolator bolt fix. Anyone else have thoughts?
2000 Windstar LX 3.8
1995 Contour GL 2.5
1986 Mustang GT 5.0 --> Sold, but missed on sunny days
Old 06-24-2011, 08:53 PM
Thanks for the info but now I'm really confused.
I changed the batteries in the 2 remote fobs this morning to eliminate that as a possibility and suddenly they both started working again.
I thought that it was just one of those strange coincidences but this afternoon neither works anymore from outside the car.
Inside the car, however, they both work fine but when they are more than about 3ft away from the receiver module, they are out of range. Do you know how the remote entry antenna is wired so I can try to trace it?
Thanks,
James
Programming Keyless Entry for MAZDA 6 Mazda6ownr 6 7 09-26-2013 04:46 AM
98 ford explorer stalling, error 171 174 hsd Explorer | Explorer Sport Trac 8 01-18-2010 11:43 PM
94 s10 remote keyless entry programing instructions needed stillblazin Problem Diagnosis 0 07-01-2009 09:39 PM
remote keyless entry problem smity9089 Intrigue 0 04-13-2009 11:45 PM
