Go Back   Automotive Forums Car Chat > Chevrolet > Camaro | Firebird > F-Body Problem Diagnosis
F-Body Problem Diagnosis Got a problem you can't fix? Post here and one of our members will answer as soon as possible.
Old 06-23-2011, 08:23 AM
blazin911 blazin911 is offline
fuel injectors
hi all its been a longtime for me ive learned a great deal from you all and im
very greatfull and appreciative. im down here in puerto rico fixin my brothers 95 camaro 3.4 v6 i pulled out the plenum as to remove the injectors cause the gas was gushing out. incredibaly the car still started anyway i pulled the fuel rail out and all the injectors wer rotted and split in half it was nuts i replaced them with new ones OE injectors i trippled checked the vacum lines according to the threads on here and now that everythings on im having an engine light and the car has a miss to it like its gonna turn off i also found it difficult to put the plugs on could it be that one or more plugs for the injectors arent making contact any ideas please my brothers been in the hospital for 4 months these hospitals up here really suck i want to have his car running for when he ges out. im extremely indebt to you guys thank you so much for doing what you do.
Old 06-23-2011, 08:26 AM
kevinande's Avatar
kevinande kevinande is offline
Re: fuel injectors
I would re-check everything just to make sure. Make certain you replaced all the wire connectors on the injectors and they are seated properly. Also check any other connectors you may have disconnected during the repair.
Old 06-23-2011, 08:38 AM
Re: fuel injectors
ok ima go and recheck everything you know i have a feeling i might have
switched to plugs on the injectors i had them marked as to not mix them up but theres one in my mind could not pluging them in all the way cause a problem i heard some of them click and some not im not sure there making contact ill be back in a while thanks
Old 06-23-2011, 10:48 AM
Re: fuel injectors
ok im back triple checked everything found out i accidentally switched two fuel injector wires. thanks for helping me out this is bigger than you think im going home to the states tomorrow i fixed my brothers montero and the camaro now he has transportation to get to his heart appts thank you all for your help im blessed to be part of this community your help has gone a long way. and to those who read this thread check everything four for five times its worth it.
Old 06-23-2011, 12:32 PM
kevinande's Avatar
Re: fuel injectors
I am glad you have the problem solved. I hope your brother gets better as well.
2003 Mustang GT - Injectors & MAF?? ndean52 Performance 1 05-03-2010 11:26 AM
help! fuel injector problem Suzannes Caravan | Voyager 9 11-07-2009 01:06 PM
91 astro vin z fuel cutout/stall prob wolf8963 M Bodies 19 08-24-2009 08:26 PM
91 4.3 Injectors Will Not Pulse chaddeaton Problem Diagnosis 1 03-10-2009 05:33 PM
FS: JDM RWD SR20DE Fuel Injectors and fuel rail ky_infiniti2000 Classifieds 2 12-06-2001 02:27 PM
