Old 06-23-2011, 01:18 AM
GregGP GregGP is offline
Intake Plenum Gasket, or Valve Cover Gaskets
I have a couple of small puddles of oil sitting on the intake manifold between the injectors on the front side of the engine. It's a 2001 GP GT 3800 SII N/A. It's only got the oil pooling on the front side of the enigne. I'm wondering if this is probably indicative of just a bad valve cover gasket?
Old 06-23-2011, 09:09 AM
GTP Dad GTP Dad is offline
Pontiac Guy
Re: Intake Plenum Gasket, or Valve Cover Gaskets
Valve cover gasket needs replaced. If it were the intake gasket you would see coolant rather than oil. These gaskets, especially if the valve cover gaskets are the originals. Usually the oil will leak from the lower side and run onto the exhaust. I would also check the area around the PCV valve as it could leak too.
Metal intake plenum for 3800 jarl Trans Sport 3 10-31-2009 07:55 AM
How to change your lower intake manifold gaskets and valve cover gaskets drdd How-to | Technical Info 20 09-12-2009 12:44 PM
2000 Blazer lower intake plenum coolant leak Sedatedbylife Problem Diagnosis 8 06-27-2009 10:20 PM
Intake Gasket & Valve Cover Gasket How-To...?? Baugzie Grand Prix 3 01-27-2005 01:06 PM
88 4Runner, I took apart the intake to get to the valve cover gaskets. VTISC007 4Runner/GX470 3 03-19-2004 08:34 PM
