Go Back   Automotive Forums Car Chat > Oldsmobile > Ninety Eight
Old 06-22-2011, 06:03 PM
ynot56 ynot56 is offline
1993 olds 98 will not stay running.
I have a 1993 olds 98 and it will not start unless i give it a little gas and when i let off the gas it turns off. Any ideas? I think it may be the fuel pump but where is it located?
Old 06-22-2011, 08:20 PM
maxwedge maxwedge is offline
A990 racer
Re: 1993 olds 98 will not stay running.
Not clear here you mean, if you don't keep your foot on the gas pedal it will stall?, will it restart, can you drive it, not enough info here, btw the pump is in the tank.
Old 06-22-2011, 08:32 PM
It will stall if i do not keep my foot on the gas pedal. I can drive it once it is on the road its fine but as soon as you con to a stop it dies out unless you keep your foot on the gas. Yes it starts back up.
Old 06-23-2011, 09:05 AM
A990 racer
Ok, there is an idle control valve that could be bad, it's on the throttle body, also the egr could be stuck open, just 2 common possibilities.
1993 3.8 will not stay running on own.. norms440 Regal 2 09-22-2009 12:53 PM
97' Buick lesabre will start but will not stay running.. HELP ME !! Duane867 LeSabre 5 01-24-2009 06:47 AM
99 Yukon Will not stay running when cold ddogdbp Yukon 1 05-26-2007 02:32 PM
my freinds car will not stay running HONDACIVICSI1990 Let's get Technical! 0 07-18-2004 10:52 PM
96 Grand Am will not stay running CJ3 Grand AM 0 04-28-2004 08:25 PM
