Old 06-21-2011, 10:34 PM
dickie1270 dickie1270 is offline
1998 looses fuel pressure
I have a 1998 GTP, i had my water pump replaced last week, every thing went fine for about 5 miles then it started cutting out of power. My rpms died to 0 but it fired back up when i hit the gas. this lasted 2 blocks before it died completely. i put it in nuetral and it would not start up. I pulled the relay fuse and bent the tab over to put the fuel pump into high mode, but still wont start. So i bought a fuel pressure gauge and when i turn the key on without engine running it goes over 50 but when i try starting the car it slowing dies down to 0. What should i try next? It also isnt throwing any codes. before i replaced the locked up water pump it would start and run for about 5 second then die.
Old 06-22-2011, 10:46 AM
GTP Dad GTP Dad is offline
Pontiac Guy
Re: 1998 looses fuel pressure
Welcome to AF!!
This sounds like a problem with the fuel pressure regulator. If you have 50 PSI when the pump is running but not the engine it is possible that the regulator has failed and is not maintaining the proper pressure while the engine is running. The regulator is located in the front of the engine so pull the vacuum line and see if you get fuel from the port if you do then the regulator is bad and needs replaced.
Old 06-22-2011, 01:37 PM
rkvons's Avatar
rkvons rkvons is offline
Are you sure you did the bent pin on the pump relay properly?
Old 06-22-2011, 04:57 PM
I replaced the resistor and still nothing. It seems that its not firing at all. any ideas?
Old 06-22-2011, 08:15 PM
Pontiac Guy
Ignition module or Crank position sensor! Try the CPS first.
Reading high fuel pressure (carbureted) caffeineaholic Caprice 16 09-25-2010 03:55 PM
For Sale New adjustable fuel pressure regulator Malbe3 Parts for Sale 0 08-07-2010 07:32 PM
96 Tahoe Fuel Pressure Issues mcmyket Tahoe 3 09-17-2009 10:09 AM
fuel pump pressure specfications dieter LeSabre 7 07-29-2009 03:05 PM
97 Blazer low fuel pressure new pump stalls in gear ChevyFamily Problem Diagnosis 6 06-05-2009 07:12 PM
