Old 06-18-2011, 01:41 PM
derekb45 derekb45 is offline
Angry 2000 alero Radiator drain plug problem ???
2000 Alero, 3.4 v6. I recently changed the water pump. drained, flushed, and refilled the coolant. twice since then the Radiator drain plug will come loose when driving down the highway...... coolant every where, car over heats.
The first time it happened I thought maybe I didnt close it properly when i did the water pump.. now that it has happened again I am pretty sure there must be a problem with the plug, or the radiator itself. Any thoughts on this woud be apreciated !
Thanks
2001 Durango 4.7L radiator drain plug mcknt Durango 0 09-26-2009 12:52 AM
2001 Olds Alero Battery Drain Issue Xenokira Alero 3 04-20-2009 10:04 PM
radiator drain plug location on 2000 Regal jrsick Regal 3 07-11-2008 04:52 AM
Radiator drain plug removal 2000 JXI 2.5 gls02 Sebring | Sebring Coupe | Convertible 0 04-14-2006 08:15 PM
2000 Dakota Radiator drain plug location? DMT78 Dakota 2 04-03-2005 06:38 PM
