Old 06-18-2011, 01:31 PM
cooncatbob cooncatbob is offline
p0101 error code
I'm getting a p0101 code in my 03 Astro van with 90k.
Which of the 2 plugs right after the air cleaner is the MAF sensor?
Old 06-19-2011, 10:11 AM
Blue Bowtie's Avatar
Registered Offender
Re: p0101 error code
The two-wire connector directly behind the air cleaner box is for the intake air temperature sensor. The connector behind that is for the mass air flow sensor.
A P0101 can be caused by a poor electrical connection, intermittent intake air leaks behind the MAF, a contaminated/dirty MAF, or electrically failed MAF. Those intake air leaks can be in the ductwork, at the throttle body, valve covers, PCV system, and vacuum lines and vacuum operated devices.
Old 06-20-2011, 11:13 AM
I have this problem since I removed the inside engine cover for the California smog inspection.
The van passed no problem but I had a very hard time getting the engine cover to line up.
I finally gave and it wouldn't start at first and then ran rough.
It seems to be running okay, but first it threw a miss fire code which I cleared because and then several months later it's thrown this code.
I think something got moved during the cover reinstallation but don't know what to look for.
Old 06-21-2011, 08:11 PM
Registered Offender
Look for interference with the distributor by the foil heat shield facing and damage to the upper vacuum lines from crushing or pinching.
P0101 and 3 more codes ken_man_1 Silverado 4 08-03-2010 07:49 AM
2002 Astro codes p0101 and p0106 wmako M Bodies 5 05-27-2010 01:08 PM
01 Town & Country error code explanation jehanny Caravan | Voyager 3 10-14-2009 12:34 AM
Error Code P0101 and Idle Air Controller mbhudd LeSabre 15 09-03-2007 08:34 AM
Stalling, Bad Error Codes, Strange Error Lights mrwjr2003 Regal 0 05-21-2004 09:34 AM
