Old 06-18-2011, 10:32 AM
gonzoblazer gonzoblazer is offline
Question on sec air pump
Im in the market for a newer blazer. i have a 98 and am not getting rid of it, ever! i was curious about the sec air pump and if it was available for both 4.3 v6 vin W and X. and i was also wondering if K18 is the rpo code for it. if its not K18 then what is the proper rpo for the sec air pump is. tryin to stay away from a blazer with sec air pump. just a prefrence i have.
Old 06-18-2011, 08:48 PM
old_master's Avatar
Advisor/Moderator
Re: Question on sec air pump
You are correct about RPO K18. If that code is included in the RPO code list, the vehicle is equipped with the Air Injection Reactor, (AIR) system. The "X" engine code indicates that the fuel injectors are located at the intake ports. The "W" engine code uses a centrally located single injector on 1995 and older engines. 1996 and newer "W" engines use 6 mini injectors centrally located in the plenum. The AIR system was used on certain, (not all) "W" and "X" engines starting in 1999.
You have to know how it works,
to figure out why it doesn't.
DTC P0410 Sec Air Injection - How to Repair and Part#s muddog321 How-to | Technical Info 14 12-02-2015 11:04 AM
Secondary AIR Pump Relay Question FireDude312 Problem Diagnosis 7 11-15-2009 05:59 AM
Air Pump Question North Coast Hotrod Dakota 0 10-26-2006 07:33 PM
Fuel Gauge and Air Pump Question rkjimmy2001 Jimmy 0 01-26-2006 07:56 PM
13B air pump question btinsley RX-7 1 03-10-2004 07:39 PM
