Old 06-17-2011, 02:27 PM
Deb Kirkpatrick Deb Kirkpatrick is offline
P1315 code after TSB repairs for P0171 & P0174
I'm going nuts trying get this 1999 Ford Windstar to run correct. It has a rough and sporadic idle. It has been sitting for the last 6 months except for trial runs after repairs. Sometimes it runs fine after a repair then the next day back to the spoardic idleing and dying. I replaced the components and gaskets (Auto Zone Valve cover repair kit $99) for the TSB for DTC PO171 and P0174. Since then the DTC is now registering a P1315 (manufacturers Control Ignition System or Misfire) . I'm beginning to think it is the PCM that is malfunctioning since this year and model's ignition is controlled directly by the PCM.
I replaced the MAF sensor, Camshaft Position Sensor, Throttle Body Sensor, spark plugs, wires, and new coil pack before I did the TSB repair.
Before I did the TSB repairs it showed codes P0430, P0340 (camshaft position sensor), P0171, P0174, and P0302(cyl 2 misfire) as pending. And the P0171 caused the freeze frame.
Now, after the TSB repairs I'm getting DTC P1315 caused freeze frame, P0301 (cyl 1), P0305 (cyl 5)
and P0340 even though I had already replaced the camshaft postition sensor.
Any help is appreciated!
PS: other code data showed EGR and Fuel System monitors - OK and the O2 and EVAP incomplete. Also, it was showing lean on banks 1 & 2 before the TSB repairs. Now it it smells like gas (rich) after the TSB repairs.
Deb Kirkpatrick
Old 06-17-2011, 06:04 PM
olopezm's Avatar
olopezm olopezm is offline
Send a message via MSN to olopezm Send a message via Skype™ to olopezm
Re: P1315 code after TSB repairs for P0171 & P0174
Is the van shaking?
The DTC points to a misfire problem, the raw fuel smell also does.
The first thing would be to inspect the plugs and wires, maybe during the repairs you damaged one or was already damaged; MORE IMPORTANT than plugs and wires is the coil pack. Remove it and inspect the back of it; it is known to crack at the back and cause arching to ground resulting in random misfires.
Oscar.
1995 Lincoln Town Car 4.6 Signature
1997 Pontiac Grand Prix GT 3.8
2000 Ford Windstar SE 3.8
01 Pathy P0171 & P0174 O2 codes SES pennywz Pathfinder | Terrano | QX4 | Xterra | Patrol | Safari | X-Trail 1 10-01-2008 11:03 PM
codes p0171 & p0174 airsslt24 Silverado 5 05-26-2007 05:09 AM
1998 Windstar P0171 & P0174 Codes Freakzilla69 Windstar 4 11-10-2006 04:19 PM
P0171 & P0174 OBD Trouble Code drewlane Continental 1 12-07-2005 02:42 PM
