Old 06-16-2011, 09:15 AM
OffroaderSWE OffroaderSWE is offline
GMC Jimmy AWD
Hi, I´ve got a Jimmy with fulltime AWD from 1994 with 4,3l Vortec, 4L60E transmission.
The awd does´nt work, it does´nt matter if i have it in Hi or Low gear. There are no strange sounds and the Hi/Low works great but I have no AWD.
What can be the problem?
I´ve tried to search but did´nt find something helpful.
THANKS!
Old 06-16-2011, 02:53 PM
MT-2500's Avatar
MT-2500 MT-2500 is offline
AF - Advisor
Re: GMC Jimmy AWD
THANKS!
What transfer case do you have?
The ID is on back of it.
Is it a floor mounted shifter for 4W?
With 2W AND 4W AND 4W low
Are you sure it is full time AWD drive?
How are you checking for no AWD?
MT
The Following User Says Thank You to MT-2500 For This Useful Post:
OffroaderSWE (06-17-2011)
Old 06-17-2011, 07:12 AM
Re: GMC Jimmy AWD
I only have one button that says: "4 hi, 4 lo". No other buttons. I just checked and the transfercase is a NP 233 c. I checked the 4wd in a gravelslope and only the rear wheels would spin. The hi and low range works but no 4wd.
Old 06-17-2011, 08:06 AM
Scrapper Scrapper is offline
AF Premium User
Re: GMC Jimmy AWD
sounds like to me as advisor said on 4 drive and it don't sound like all wheel drive.
The Following User Says Thank You to Scrapper For This Useful Post:
Old 06-17-2011, 09:51 AM
Re: GMC Jimmy AWD
I maneged to find the problem.
First you had to double tap the 4hi button to get 4wd, an then i found a vacuum leak. That was the major problem and with that fixed, that PROBLEM SOLVED
1: I have another problem too, I´ve got problems with the emissions. They are too high. All emission values is not stable, they go up for a while and then goes down. Bot not enough! I have changed rotor, distributor cab, sparkplugs and wires but that did´nt solve the problem. The car runs wery well now after the changes.
Where should I begin to try solve this?
2: My transmission is resently rebuilded whith new turbine and masterkit but the 3 and 4 gear has stopped working, I have heared that it might be some valve by the oilpan filter, what do you think?? Its a 4L60E.
Thanks!
Old 06-17-2011, 12:14 PM
MT-2500's Avatar
AF - Advisor
Re: GMC Jimmy AWD
Thanks!
You are welcome.
I think.
OK you have a SELECTIABLE 2-4 wheel drive.
With the crazy control button that you have to get out the opertors manual to find out how to shift it 2 to 4W.
All wheel drive is in 4w DRIVE ALL TIME.
Recheck emmisions and engine running after fixing the vacuumn leak.
On the transmission you need to get it on a trnsmission/engine capable scanner and check shifting and for transmission and engine codes.
Post back all code no.
Then clear codes and recheck for codes because the vacuumn leak could have set some old codes.
MT
Old 06-18-2011, 09:46 AM
Re: GMC Jimmy AWD
I shall test the emissions om monday, I´ll get back with the results.
Ok, I´ll try to find a scanner for the engine. But I´ve heared that you can blink the trouble codes, how do I do that?
Old 06-18-2011, 10:15 AM
Re: GMC Jimmy AWD
I maneged to flash the following:
1 long, 2 short. flashed 2 times in a row. (12 System normal) then:
3 short, 4 short.
Shall I take that as 13, 14? (13 oxygen sensor circuit open, 14 coolant sensor high resistance or shorted)
I´m going to visit my GM dealer on monday.
Old 06-18-2011, 02:13 PM
MT-2500's Avatar
AF - Advisor
Re: GMC Jimmy AWD
3 short, 4 short.
YOU SHOULD HAVE LONG FLASHES FOR THE FIRST NO.
THEN SHORT FLASHES FOR THE 2ND. NO.
YOU HAVE TON WATCH RELMCLOSE FOR A LONG OR SHORT FLASH
LIKE 1 LONG = 10 FIRST PART OF NO.
2 LONG FLASHES PUTS IT UP TO 20
1 LONG AND 3 SHORTS - 13
2 LONG AND 4 SHORTS = 24
But first thing you have to clear codes and then run and drive and recheck
MT
Old 06-20-2011, 09:55 AM
Re: GMC Jimmy AWD
I rechecket the codes and it was code 34 and 44.
34: map sensor signal out of range, low
44: oxygen sensor lean exhaust
I bought a new oxygen sensor and I´m going to replace it tomorrow. Were is the Map-sensor located on my engine?
Old 06-20-2011, 11:33 AM
MT-2500's Avatar
AF - Advisor
Re: GMC Jimmy AWD
Code do not say throw parts at it.
Map sensor.
With AT transmission facing engine right hand side of EGR valve.
I would work on map sensor problem first.
That coulld be throwing a 02 sensor code.
Make sure wiring and plug in is good.
let us know how it goes.
MT
Old 06-21-2011, 10:50 AM
Re: GMC Jimmy AWD
I changed the oxygen sensor today and the emission problem is gone! . After the change I erased the troublecodes and took it for a drive, runs very well now
I can now say: THAT PROBLEM SOLVED!
Now it´s just the tranny left...
Old 06-21-2011, 11:21 AM
MT-2500's Avatar
AF - Advisor
Re: GMC Jimmy AWD
Thanks for posting back the fix.
Drive and recheck for codes.
Good luck
MT
Old 06-22-2011, 08:32 AM
Re: GMC Jimmy AWD
No troublecodes yet I am wondering if you know what rear axle I´ve got? I think I´m going to invest a difflock
Old 06-22-2011, 09:43 AM
MT-2500's Avatar
AF - Advisor
Re: GMC Jimmy AWD
You need to gm dealer run your vin no or check RPO code or tag on rear end plate or just pull inspection plate and check ring gear for ratio.
MT
1996 GMC jimmy surging 600cuin Jimmy 1 10-05-2010 06:37 PM
96 GMC Jimmy Help....O2 Sensor?? corhey88 Jimmy 1 02-15-2010 06:24 PM
96 GMC Jimmy black smoke, backfires, Timing? corhey88 Jimmy 38 01-31-2010 03:29 PM
Blowing ECMb fuse 1990 gmc jimmy 350 bmxer20n Problem Diagnosis 1 07-10-2009 05:47 PM
87 jimmy wont start Chevygirl04 Problem Diagnosis 1 04-09-2009 06:44 PM
