Old 06-15-2011, 06:16 PM
wolfden6 wolfden6 is offline
1998 K2500 tach problem
I have a 1998 k2500 with a 5.7....I was sitting at a stop light today and idling and when I looked down the tach was dead...It was working fine up to that point and all other gauges work fine, just no tach.
I checked all of the fuses and they are good....Any ideas??
Thanks
Old 06-16-2011, 07:27 PM
777stickman 777stickman is offline
Re: 1998 K2500 tach problem
My '98 book shows the tach, speedo & tranny selector lights coming from the TRANS fuse. So if the speedo's working ok it must be good. Both speedo and tach share the same ground. So, it could be either the tach signal from the coil or the tach itself.
Hope this helps, your neighbor in Maybe.
57 Chevy 210
65 Olds 442 Convertible (Another one sold)
75 GMC Vandura 3/4 Ton
1999 K2500 Old Body Style Suburban (Gone but not forgotten)
05 Dodge Ram 3500/5.9 Cummins
2012 Toyota FJ Cruiser
Old 06-16-2011, 08:36 PM
I did replace the coil about 1000 miles ago and replaced the stock coil with a Hypertech coil with a little more juice...Do you think that a hotter coil could have screwed up the tach????....I sure hope not...like I said it worked good for 1000 miles and then stopped...could just be a coincidence I hope...any thoughts
Old 06-17-2011, 10:34 AM
White wire at the coil is the signal to the tach. Recheck the connection.
57 Chevy 210
Old 06-17-2011, 07:55 PM
Should that wire have current to it with the key on ??
Is there any way I could check the circuit with a volt or ohm meter to see if the wiring is the problem or if the tach itself is the problem
Old 06-18-2011, 05:42 PM
Check your Private Messages.
57 Chevy 210
Old 07-24-2011, 01:39 PM
Well I got in the pickup a few days ago and started it and low and behold the tach worksI have only driven it about 5 times since the tach stopped working and it is working perfectly...Very strange indeed, don't know why it stopped working but it is wroking fine for now...we'll see what happens next
1998 Oldsmobile Achieva--TRANSMISSION WON'T SHIFT... rheji Achieva 2 05-08-2012 11:42 AM
1998 Sentra SE Problem Neifert Sentra | 200SX (USDM FWD) 1 01-10-2011 08:43 AM
possible ford transmission problem synthetic003 Expedition 2 09-22-2010 10:33 AM
Max AC Clicking/Tach Problem tominton Cavalier Problem Diagnosis 1 07-09-2009 03:27 PM
1998 k2500 6.5 Turbo Diesel bigj-dog C/K 3 03-14-2006 12:07 PM
