Old 06-14-2011, 01:17 PM
WestMemphis WestMemphis is offline
In desperate need of help!!!!?
I have a 1996 Lumina 3.1. It wouldn't start for more than three weeks. It would turn over/crank, but would not start. I replaced spark plugs, intake plenum gasket, and made sure fuel pump worked and had fuel in the tank. It was getting gas to the fuel pressure tester, but seemed like it wasn't getting gas thru the injectors. Yesterday I replaced the crank sensor and viola ... it started, idled, and I drove it up and down my drive way. This morning, went to start it up......and the same darn thing.... just cranks but does not start? Any help/suggestions would be welcomed and greatly apprieciated. I am by no means a mechanic, nor do I pretend to be. Everything I done to my car was from what other people had told me, or from the countless hours of research on the internet. Thanks in advance for any help whatsoever.
Old 06-14-2011, 06:55 PM
maxwedge maxwedge is offline
A990 racer
Re: In desperate need of help!!!!?
Welcome to AF. See if it starts with a spray of starting fluid, any spark or injector pulse?, basic diagnostics for this condition.
Old 06-20-2011, 08:11 AM
Mediaman67 Mediaman67 is offline
when it doesn't start, check your fuel pressure with KOEO - and if it's less than 30psi, this is a good place to start...
if you have fuel, I would say it's your ign module and/or coil packs...
Old 06-20-2011, 04:52 PM
jeffcoslacker's Avatar
jeffcoslacker jeffcoslacker is offline
Lactose the Intolerant
I'd be looking at my CKP sensor wiring and terminals real close...if it started up after replacing, then crapped again, it may be that it was actually a wiring/contact issue there that you temporarily changed when you played with the pigtail to it while replacing the sensor. Follow the wiring around and make sure it's not burning or rubbing on anything, terminals aren't pushed outta place in the plug, etc.
If not, do what Max says, or you're swinging in the dark...
You made three mistakes. First, you took the job. Second, you came light. A four man crew for me? F**king insulting. But the worst mistake you made...
...empty gun rack.
Desperately Need Help - 1995 Pa Ultra PYROMANIAK777 Park Avenue 14 06-01-2005 08:37 AM
Desperate!! Need help with driver door handle!!! richrock Explorer | Explorer Sport Trac 2 10-11-2004 10:56 PM
Desperately Need Help!! nosubstitute959 Corolla/Matrix/Voltz 3 04-26-2004 03:10 PM
Desperately Need Help!! nosubstitute959 Accord/TSX/Accord Hybrid 3 04-24-2004 09:14 AM
I desperately need help suprman General 3 10-20-2003 12:00 PM
