Go Back   Automotive Forums Car Chat > Dodge > Ram Pickup | Ram SRT10
Old 06-13-2011, 09:42 PM
spencersavory spencersavory is offline
P0500 Code.
2002 ram p0500 code changed both sensors code is still their speedometer dont work odometer dont work hvac dont work door lock dont work. brake,antilock,airbag lights on. need help allfuses ok wires ok
Old 06-18-2011, 05:14 PM
Chris Stewart's Avatar
Chris Stewart Chris Stewart is offline
AF - Advisor
Re: P0500 Code.
Sounds like a ground issue.
Clean all battery cables on at a time.
There's supposed to be a ground post behind the driver's side kick panel, clean the wires grounded there.
You are referring to changing the speed sensor on the rear differential, right?
1992 Bravada, 201K, stock
1997 Bravada, 101K, stock...was "called away"
"Cornbread Red", 2001 Dodge 2500,4X4,HO Cummins Diesel,QC,SWB,6spd.,Banks boost&pyro,US Gage fuel press.,Edge Drag Comp,4"exh.,cowl hood, bhaf, black Holley pump, 140gph...13psi WOT, Vulcan Big Line, kevlar/ceramic single disc clutch, cheapo fuel cooler, 8x.010" vco injector nozzles, Cat turbo 62-65-.70A/R, 497hp 1089 tq 8/25/14
Time to turn so's you don't burn.
trouble codes danielgast46 F Series 6 04-06-2009 07:06 AM
1993 Acura integra Stereo Code Omega-Factor Interior | Audio | Security 1 03-25-2009 07:08 PM
01 Sport Trac Door Code??? levi.calhoun Explorer | Explorer Sport Trac 1 03-23-2009 10:09 PM
VSS vehicle speed sensor P0500 code krk105 Windstar 1 04-13-2007 06:13 PM
p0500 code on 97 chev 97chevyman C/K 2 03-24-2004 10:47 AM
